Question about Polaroid Tablet Computer PMID701
Authentication problem connecting to wifi
Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
Posted by Cuzin Bob on
Elaine Kipp
    New Friend:
Posted on Dec 31, 2012
  • 1 more comment
  • Priscilla Mar 19, 2013
    Try resetting password,and make sure password is correct.
    I did that to my Emerson tablet last night. password letters look like numbers.After figuring out the correct password, it is working okay.
  • Alex sitole Mar 26, 2015
    My problem is solved now
I cannot get it connected it just keeps saying authentication problem and will not connect to wifi this is a nes tablet just purchased
Check your wifi password correctly. If you are the owner of the wifi router you are connecting try to press the refresh icon button located on the side of your router.
Mar 20, 2015 | Tablets & eReaders
My new Nexus 7 wont go past the "Select Wi-Fi" screen although I have set the Wi-Fi up
I assume you're using a secure Wifi connection with a password and it seems like that authentication is not working. You could try using an open wifi access point to eliminate the possibility of this authentication issue.
Oct 04, 2014 | Google Nexus 7
How to connect my tablet to wi-fi
Authentication often means "password protection" for the specific wifi connection. Usually your software will present a "dialogue" box telling you a password is necessary and give you an opportunity to enter one.
Jul 31, 2014 | RCA CA 7" Tablet with 4GB eory 28458515
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
Feb 11, 2014 | Craig CMP741d Tablet
Meep will not connet to wifi
Here is the remedy for that error:
We've heard a few reports of Wifi connectivity issues recently, among them 'Authentication error'. If you receive this message, our recommended remedy is to remove all Wifi connection information from your Meep, turn off your Meep, reboot your router, then turn on your Meep and re-add the Wifi information. Follow these steps exactly in this order to resolve this error message:
1. Remove all Wifi network information from the Meep's settings
2. Reboot your router
3. Re-add the Wifi network information to the Meep's settings
4. Reboot the Meep.
Jan 01, 2014 | Oregon Scientific MEEP Kids Tablet
My SVP tablet (Model TPC0902) will not connect to my home WIFI. I keep getting this message "authentication problem." How do I fix this? (All my other devices connect just fine)
Tablet worked fine on wireless for first two weeks. Now it's showing a line flickering in the wi-fi icon. I checked Ethernet and reset router button. Nothing.
Aug 11, 2013 | Tablets & eReaders
Why does my tablet keep saying authentication problem when trying to connect to wifi
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Dec 30, 2012 | Archos Arnova 10 4GB 4)
Polaroid Tablet Computer PMID701 Logo
3,721 people viewed this question
Top Polaroid Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
