Issa Abakar Hamid Posted on Mar 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi! How to fix error code 092-315 for xerox 7225?
NICK FIRTH
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Xerox Expert 129 Answers
  • Posted on Mar 15, 2016
NICK FIRTH
Xerox Expert
Level 2:
Passionate:
Answers
129
Questions
0
Helped
110564
Points
234
That is a black drum atc failure. First try to replace the black image drum and if that doesn't resolve it can be the MCU Board.
Xerox 7225 Blocked Interrupt Button keep Flashing
If turning the machine on and off and on again does not clear the problem, your best bet is to contact Xerox support for the machine. That is what Xerox advises. I could suggest going to the printer driver for it on the server and seeing if you can reset that BUT that could waste your time and demand expertiese not at hand. I'd rather not lead you down the primrose path.
1helpful
2answers
Model 560. What does error code 062-395 indicate?
http://www.manuals365.com/swf/fuji+xerox/ag-c560p_c550p.html?page=207
How to fix Fault code 004-346 on Xerox Workcentre 7346
You can fix Fault code 004-346 on Xerox 7346 by following these steps:
  1. Make sure all shipping restraints
  2. Run the Belt Edge Learn Test from the diagnostics
  3. Reseat the Accumulator Belt
  4. Did the error clear?
  5. If not replace the Accumulator Belt 6.If the error still continues replace the Engine Control Board
For the more detail visit the link:
https://www.orionmarket.com/product_error/14541/Xerox/Phaser-7760/xerox-7760-error-code-004-346
2helpful
2answers
Xerox WC 5330 error Code 010 338
Hi
Iam KISHORE
Xerox 5335 error code 10-338 plaze slow tellme tha problem
Hi!Can you help me resolving error code 092-315 for xerox7225?
Can you verify the error code? 092-315 does not appear in the error code site. See link below
How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
Viewing Fault and Alert Messages on the Control Panel
When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
To view a complete list of active fault and alert messages:
  1. Press the [Machine Status] button on the Control Panel.
  2. Select the [Active Messages] tab.
  3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
  4. To view details, select a fault or alert.
Viewing the Fault History on the Control Panel
When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
To view the fault history:
  3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
The following table represents the system area as represented by the first 3-digits of the fault code:
Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
Xerox WC 7225 error 303.316.00 - how to solve?
Your best bet is to go to the Xerox.com website and follow the troubleshooting guide.
Good luck.
2helpful
2answers
Can you tell me what error code 124-315 means on Xerox Docucentre-II 2055 ? and what the recommended fix is. (Multifuncton printer). Thanks, Gajj
hi
regarding your error go to following link
http://www.copytechnet.com/forums/xerox/36062-xerox-docucentre-ii-2055-error-016-315-a.html
Error code 07,005.30553
Hi rita619:
Your process gear motor is giving you a problem. You have to call Xerox and have them fix it for you. WWW.Xerox.com
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
