Question about Xerox Office Equipment & Supplies
Hi!Can you help me resolving error code 092-315 for xerox7225?
  • Xerox Master
  • 1,682 Answers
Can you verify the error code? 092-315 does not appear in the error code site. See link below
How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
Viewing Fault and Alert Messages on the Control Panel
When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
To view a complete list of active fault and alert messages:
  1. Press the [Machine Status] button on the Control Panel.
  2. Select the [Active Messages] tab.
  3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
  4. To view details, select a fault or alert.
Viewing the Fault History on the Control Panel
When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
To view the fault history:
  3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
The following table represents the system area as represented by the first 3-digits of the fault code:
Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
Posted on Mar 07, 2016
Anonymous
SOURCE:
It keeps showing an error code C0. what does this mean.
Hi, I cannot find this error code for your dryer.
Does the dryer have other faults?
The Technical manual for the drier shows error codes, but does not include CO. The manual will help with resolving problems you may have as it has detailed instructions for troubleshooting and the solutions. See the diagnostic tests. You can also clear diagnostic codes, which may resolve this problem if there are no other problems with the drier.
You can download the manual from
http://www.manualslib.com/download/763426/Amana-Ned7200tw.html
Hope this helps you :)
Mar 04, 2015 | Amana NED7200TW Electric Dryer
An error code mp258
Hi Hanisah,
I have this site for you on how to know and resolve errors on your device. Hope it helps.
Canon Pixma MP258 Error Code PC Mediks
Apr 25, 2014 | Office Equipment & Supplies
Error code mp258
Hi Abuhasan,
Apr 25, 2014 | Canon Office Equipment & Supplies
I received an error code 0X490 in the system files integrity check and repair. What is this and how do I fix it?
Copy and paste the following link into your internet browser for details on this error:
http://social.answers.microsoft.com/Forums/en-US/vistarepair/thread/efa79e48-1ef6-47d1-85f2-1b1e374c0ec2
Feb 18, 2011 | Dell Inspiron 1525 Laptop
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
Sony a100 error 56
The Error code indicates the Self diagnostic message of the Camera. This message can be clearly identified by the help of a Sony Authorized service technician. The
Error code 56 indicates an issue which can be resolved by the help of a service technician. This error code may be an issue with the Shutter mechanism. Try resetting the Camera by selecting the Reset Default option in the Setup Menu 3 option. Also, try removing and reinserting the battery after 1 minute. If not resolved, get the unit serviced.
Thanks.
Oct 21, 2010 | Sony Alpha DSLR-A100 Digital Camera
Code error h2
Hi
Error code H2 means fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor or due to fusing lamp. To resolve this error try and reset the unit by entering the service mode--
press # - INTERRUPT - C - INTERRUPT
then
14
start
If this resolves your issue then try restarting the printer and try the reset again. However, if reset is not helping you then you
Oct 09, 2010 | Sharp AR-5316 Advanced Digital Imager...
Hi! I'm getting an error code of 2,114,0 when i tried to scan a pic. How do i resolve this? Thanks!
Oct 08, 2010 | Canon PIXMA MP190 All-In-One InkJet...
I recieved the following error code on my gas range with self cleaning oven... error code E2 F1... PLEASE HELP ME
Hi
Thanks for using FixYa. F1-E2 error indicates that the oven is too hot & the oven temperature sensor has gone bad and should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Washing Machines
Canon Pixma MP190 Error Code 23
Hi ...
As you mentioned, you have already tried the basic troubleshooting which resolves the issue most of the time ... (good job) ... but sometimes there is a different issue altogether and to resolve the same, you need to get your printer repaired ... I would suggest you get a certified tech. to check your printer.
Cheers ...
Jul 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
249 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
