Hi Thanks for your answer, have already tried that and still no go...would you know of anyone that repairs these machine as several places i have rung are not familiar with this model ? Thanks
poke something up the outlet hole .....pin or something .. or if this dont work u need service and replacement parts .. bsc appliance 07779933829 we carry out repair service via post anywere.
Try this remove all the beans using a vac cleaner, then turn to lowest-finest number, then remove screws on grinder lift chamber and turn knob to coarsest setting and reassemble and try machine, remember to adjust grind when machine is grinding.
BEFORE YOU DO HAVE IT REPAIRED TRY SOAKING THE WAND IN BOILING WATER THE MIKE SOMETIMES CLOGS IT UP AND THE ONLY WAY IS TO SOAK IT IN BOILING WATER I PUT A CUP UNDER IT AND JUST HOLD IT WHILE IT SOAKS THEN JUST LET THE STEAM DO THE REST
HI thanks for your question. the problem is with the water pump. its electric, so some of the food got caught in the pump. clean out the pump. thanks, the appliance doc. please rate my answer. thanks.
Hi Bibi - Is this a regular land line? Is the fax machine supposed to answer if it's a fax but not answer if it's a phone call? Let me know exactly what your mothers' setup is please. It sounds to me like the fax is trying to answer all the calls and the screeching she hears is the fax machine try to handshake, or connect, with another fax machine. You've probably heard what that sounds like. Let me know the answers and if you can ask some people that called if they heard anything. Thanks.
HI there below is the reason for your error message and it is to do with the laser unit and will normally need to be replaced when this message comes up.
Hexagonal mirror motor startup error 3-31
You could try resetting it by the following · Try to clear the service call condition (for failures which are not related to the fusing unit): switch the power off, wait 10 seconds, then switch back on.
I take it you have already tried this but if this doesn't work then the unit will need replacing
