Electrical Supplies Logo
Theresa Ahlm Posted on Feb 14, 2016
Almost done and lost my switch wire - General Electric Electrical Supplies
2answers
How do you replace the door switch for the door in the microwave oven?
Take the cover off, the switches should be pretty easy to replace. In the several I've done, they just snap out, unplug, and then snap back in.
I lost my key how do i hot wire a 2000 Chevy Venture minivan
can not be done easily, serious damage to ignition switch etc
1helpful
Starting engine, and holding key in the on position, engine will continue to run, but allowing the key to go backward to disengage the starter, the engine cuts off as if it were out of gas. It appears...
More than likely the ignition switch is bad, however you seem to think that a wire is wrong. Has any work been done on the vehicle just before this sympton appeared? Has the vehicle been in an accident? Has anything been done that could have cut a wire? Is this vehicle very very old? Normally wires don't go bad. However switches, relays, fuses, and fuse links do go bad. In some cases wiring harnesses connect through a connector ( a male and female connection). If these connectors are subject to heat, clold, and moisture or high current the connection can be lost as if a wire had been cut. Happy hunting.
Used the truck to jump start another truck and when got done lost power to the drivers door,pass door and four wheel drive switch and radio,sunroof and parking lights
check all of your fuses it sounds like you have a main fuse blown if that is not the problem check for good connections on wires leading from the battery
3helpful
I cant get both switches to work properly one minute it turns the light on the next they done work. is the red wire suppose to hook up to the black screw
The key to three-way switches is the dark screw.
And different brands of switches put dark screw on different side of switch.
So, lets get out of this mess with a bit of testing.
You have two switches with 3 wires on each switch for a total of 6 wires.
Take out both switches and separate wires for testing.
Turn on power and test each wire to bare copper wire.
One and only one wire will test Hot.
The hot wire goes to dark screw on switch1.
The other two wires in that box go to either screw on switch1.
One switch done, one switch to go.
Move switch1 lever to down position.
Turn on power and test 3 remaining wires.
One wire will test hot. Mark this wire.
Move switch1 to up position, and test 3 remaining wires again.
A second wire will test hot. Mark this wire.
The 2 marked wires attach to either brass screw on switch2.
The third wire attaches to dark screw.
Both switches done.
Long story but I had someone "attack" my T-72 Freezer and I'm trying to figure out what they did. I think they tried to replace the defrost switch with a non standard switch and stopped half way through...
http://www.truemfg.com/index_en.aspx?language_id=1&event_id=401
Go to this web site. Be sure to have the serial and model numbers. You can request a wiring diagram from the tech line. This is most likely your best place to start. True uses a variety of different devices so I would do this first.
Let me know if I can be of more help after you get diagram.
Hi, I have a general electric model number 5kc182ag201d motor that I want to change from 110 to 220 volts. wiring diagram lost but the wires still have the numbers on them. Also I want to change the...
This can only be done if the motor has the function to be switched. But as for reversing the rotation it is very complex, if you have starting capacitors on top of the motor then it would be required to change the wiring at the diodes and wire the starting capacitors opposite of their present configuration. This is really something for an electrical motor rewinder to address as it is over the heads of most folks. It can be done if you had the wiring schematics and the motor has the features built in for this. [email protected]
2answers
1991 E-150 dual tank, won't start. Squirting gas
what ive seen on a 1991 E-350 is that under the battery the wiring corrodes and wires break,causing no power to the key switch or the fuse box or computer.take a look it only takes a minute
Top General Electric Electrical Supplies Experts
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
ADMIN Eric
ADMIN Eric
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
