It shut down and will not come back on after it cools will it reset or is there a reset button
SOURCE: reset button keeps popping out
most common cause for heater overheat, and reset, is lint build up in the exhaust line, reduces air flow, the air gets hotter than designed, and resets pop.
some lint always gets past the screen and lodges in the fan and ducting and vent hood.
examine and clear the above, all the way to the wall, and problem should cease.
(2/3 chance)
SOURCE: Kenwood KVT-817DVD screen goes black, have to reset constantly
You will find that there is a voltage surge upon starting, solution is quite simple, try to avoid starting the engine with the unit on, as you may blow more than a fuse.
SOURCE: ESTATE DRYER EED4400WQ HEATING ELEMENT HEAT FOR
venting issue, disconnect vent tube and run dryer
