20 Most Recent Kenwood DP-J2070 CD Player Questions & Answers
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Kenwood DP-J2070... | Answered on Jan 30, 2008
Hi Michael, if your Kenwood CD 204 can play in random mode among the 5 CDs, you have the Randon button, for that function
On page 17, he explains the Randon function
I sent you the link of the user manual so you can download it
I hope you can solve your need
Greetings Franco Dosil
Hola Michael, si tu Kenwood CD 204 puede reproducir en modo aleatorio entre los 5 CD, tienes el bot?n de Randon, para esa funci?n
En la pagina 17, te explica la funci?n Randon
Te env?o el link del manual de usuario para que lo descargues
espero que puedas resolver tu necesidad
Saludos Franco Dosil
https://data2.manualslib.com/pdf/9/862/86192-kenwood/dpfr3010.pdf?e84121e9d1645b7418a0352ba4d72dd1&take=binary
Kenwood Audio... | Answered on May 12, 2019
Hello Rob, I'm looking for the Kenwood A65 user manual and I can not find it, I understand that you are looking to interconnect your equipment and be able to listen
I suggest you send me the list of equipment that you want to connect to the A65, please indicate your brand and model so you can generate an idea of interconnection and so you can solve your need
I am going to send you the link to download the service manual, in the first pages, the rear panel of the A65 appears, which will serve as a reference of where your equipment would be connected
I await your comment about your equipment
Hola Rob, estoy buscando el manual de usuario del Kenwood A65 y no lo encuentro, entiendo que lo esta buscando para interconectar sus equipos y poder escuchar
le sugiero me env?e el listado de equipos que quiere conectar al A65, por favor indique marca y modelo as? puede generar una idea de interconexion y as? podr? resolver su necesidad
yo le voy a enviar el link para que descargue el manual de servicio, en las primeras paginas, aparecen el panel trasero del A65, que le servir? de referencia de donde ir?an conectados su equipos
Espero su comentario sobre sus equipos
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Kenwood-A-65-Service-Manual.pdf
Kenwood Audio... | Answered on May 08, 2019
Hello Pandit, the sequence of connections that I suggest, is the following, you connect the tuner KT-56 in the Tuner input of the KT-76 amplifier, the Cassettera deck in the Tape 1 connections of the KT-76, and the GE- equalizer 46 on the Tape 2 connections
I sent you the link to download the KT-76 user manual
on the third page there is a description of the connections, in your case instead of cassette 2 you will connect the GE-46 equalizer
I hope you manage to interconnect all the equipment and enjoy good music
Hola Pandit, la secuencia de conexiones que te sugiero, es la siguiente, conectas el sintonizador KT-56 en la entrada Tuner del amplificador KT-76, la Cassettera deck en las conexiones de Tape 1 del KT-76, y el ecualizador GE-46 en las conexiones de Tape 2
Te env?o el link para que descargues el manual de usuario del KT-76
en la tercer pagina hay una descripci?n de las conexiones, en tu caso en vez de la cassettera 2 conectaras el ecualizador GE-46
Espero que logres interconectar todos los equipos y disfrutes de buena m?sica
https://data2.manualslib.com/pdf3/78/7752/775116-kenwood/ka76.pdf?6a142b74fc7e4a25b8f7a8d010836b1f&take=binary
Kenwood Audio... | Answered on May 02, 2019
Hello Skye, the Kenwood Multiple Compact Disc Player DP-MH5 of your dad, has a problem with a strap inside the mechanism, I suggest you take it to a specialized technical service
If you have technical knowledge, I send you the link to download the service manual, on page 16, the breakdown of the mechanics appears and shows you the belt with the number 46, that is the one that you must replace
I also sent you the link to download the user manual
Hola Skye, la Kenwood Multiple Compact Disc Player DP-MH5 de tu papa, tiene un problema con una correa dentro del mecanismo, te sugiero que la lleves a un servicio tecnico especializado
Si tu tienes conocimientos tecnicos, te envio el link para descargar el manual de servicio, en la pagina 16, aparece el despiece de la mecanica y te muestra la correa con el numero 46, esa es la que debes reemplazar
Tambien te envio el link para descargar el manual de usuario
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Kenwood-DPMH-5-Service-Manual.pdf https://www.manualslib.com/manual/203920/Kenwood-Xd-8551.html?page=17
Kenwood Audio... | Answered on Apr 29, 2019
Hi Andrew, so you have no speaker audio output on your Kenwood A-65
the A-65 has a protection system with a relay that is activated when any output is not working or burned
If you have technical knowledge, I send you the service manual,
but, approach a specialized technical service
I hope you can solve the iconveniente
Hola Andrew, por lo que cuentas, no tiene salida de audio en parlante tu Kenwood A-65
el A-65 cuenta con un sistema de proteccion con un rele que se activa cuando alguna salida no esta trabajando o esta quemada
Si tienes conocimientos tecnicos, te envio el manual de servicio,
sino, acercate a un servicio tecnico especializado
Espero puedas resolver el iconveniente
https://elektrotanya.com/kenwood_a-45_a-65_amplifier.pdf/download.html
Hello Patricia, the Kenwood KM 209, is a two-channel stereo amplifier, you can only send two signals and amplify them, for example, Left and right front or Main audio output and you will have greater presence of frontal sounds
Audio output left and right rear or Surround, you will have greater presence of the rear sounds
It has the ability to amplify only two channels only
I hope you have clarified the possibilities
I send you the user manual, so you can observe the connection possibilities
Hola Patricia, el Kenwood KM 209, es un amplificador estereo de dos canales, solo puedes mandarle dos se?ales y amplificarlas, ejemplo, Salida de audio izquierdo y derecho frontales o Main y tendras mayor presencia de los sonidos frontales
Salida de audio izquierdo y derecho traseros o Surround, tendras mayor presencia de los sonidos traseros
Tiene la capacidad de amplificar solamente dos canales solamente
Espero te haya aclarado las posibilidades
Te envio el manual de usuario, para que observes las posibilidades de conexion
https://www.manualslib.com/products/Kenwood-Km-209-3868175.html
Hello Paul, it would be good if you put what model is the Kenwood that you have
The problem may be in the laser pickup with low emission, or problems with the motors of the CD-holder plate or the transfer of the reader
Not having put the model Kenwood player, I can not send you any manual of the same
I wait your answer
Hola Paul, seria bueno que pongas que modelo es el Kenwood que tienes
El problema puede estar en el pickup laser con baja emision, o problemas con los motores del plato porta CD o el de traslado del lector
Al no haber puesto el modelo de reproductor Kenwood, no puedo mandarte ningun manual del mismo
Espero tu respuesta
Hello Laura, your Kenwoon, does not have digital audio inputs,
Neither Fiber optic input, nor Coax, nor HDMI
only stereos, if you can connect your television, if you have analog output and enter it in your Kenwood
I am sending you the user manual of the 107VR Receiver, to observe the possibilities that you have
I hope you can enjoy your equipment
Hola Laura, tu Kenwoon, no cuenta con entradas de audio digital,
Ni entrada de Fibra optica, ni Coaxil, ni tampoco HDMI
solamente entradas estereos, si puedes conectar tu televisor, si tiene salida de analogica e ingresarla en tu Kenwood
Te estoy enviando el manual de usuario del 107VR Receiver, para observes las posibilidades que tienes
Espero puedas disfrutar tus equipos
https://www.manualslib.com/manual/777099/Kenwood-107vr.html
Hello Zoe, I do not know about this type of devices, do not pay attention to your family, keep talking to the machine, in short, you work with it and it's good to get along
Good luck, I hope you understand and that you can solve the issue
Hola Zoe, no conozco sobre este tipo de aparatos, no le haga caso a su familia, siga hablandole a la maquina, en definitiva, usted trabaja con ella y es bueno que se lleven bien
Suerte, espero que se entiendan y que logre resolver el tema
Kenwood Audio... | Answered on Apr 28, 2019
Hello Jason, from what you are saying, it would seem that the problem is inside the Subwoofer speaker, I do not think it originates in the Kenwood
Before you try changing the RCA-RCA cable between the Kenwood SubWoofer output and the Subwoofer speaker input
Also control the power cable of the subwoofer, if it is with an interlook, replace it
You have not commented that Sub you have, tell me the brand and model
If with these tests, you do not have positive results, take the Sub, to a specialized technical service
I hope you can solve this issue
Hola Jason, por lo que comentas, parecer?a que el problema esta dentro del bafle Subwoofer, no creo que se origine en el Kenwood
Antes prueba cambiar el cable RCA-RCA entre la salida de SubWoofer del Kenwood y la entrada del bafle Subwoofer
Tambi?n controla el cable de alimentaci?n del subwoofer, si es con un interlook, reemplazalo
No has comentado que Sub tienes, dime la marca y modelo
Si con esas pruebas, no tienes resultados positivos, lleva el Sub, a un servicio t?cnico especializado
Espero que logres resolver este tema
Hello Wayne, for what you describe you have a mechanical problem, which does not allow the CD holder tray to come out, it is usually the belts, which lose force capacity and do not pull the mechanisms
If you have technical knowledge, I am sending you the link so you can download the service manual, there on page 31, you have the exploded mechanism of the compactera, replace the belts, marked with the number 22 and 19, but go to a specialized technical service
I hope you can solve the problem
Hola Wayne, por lo que describes tienes un problema mec?nico, que no permite que salga la bandeja porta CD, por lo general son las correas, que pierden capacidad de fuerza y no traccionan los mecanismos
Si tienes conocimientos t?cnicos, te estoy enviando el link para que puedas descargar el manual de servicio, ahi en la pagina 31, tienes el despiece del mecanismo de la compactera, reemplaza las correas, marcadas con el numero 22 y 19, sino dirigete a un servicio tecnico especializado
Espero logres resolver el problema
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Kenwood-RXD-353-Service-Manual.pdf
The first thing to check is the solder connections on the display itself. The display should have a series of pins that you will see on the PC board that is behind the front panel. Resolder the connections on either end. These are the connections that supply both the +and - sides of power. These often develop poor connections. Update this with the results of the resoldering and we'll continue from there if the problem is not resolved.
Dan
Kenwood Audio... | Answered on Apr 27, 2019
Hello Francesco, I would like to know what problems your Kenwood XD-500 has, or just want to perform maintenance
I am sending you the service manual
I hope you achieve your goals for your Kenwood
Ciao Francesco, vorrei sapere quali sono i problemi del tuo Kenwood XD-500 o se vuoi solo eseguire la manutenzione
Ti sto mandando il manuale di servizio
Spero che tu raggiunga i tuoi obiettivi per il tuo Kenwood
Saluti Franco Dosil
Hola Francesco, me gustaria saber que problemas tiene tu Kenwood XD-500, o simplemente deseas realizar un mantenimiento
Te estoy enviando el manual de servicio
espero que logres tus objetivos para con tu Kenwood
https://www.manualslib.com/manual/720696/Kenwood-Rdx-500.html
Kenwood Audio... | Answered on Apr 26, 2019
Hello Mark, ask, do you do this with FM stations, like with AM stations?
If so, you may have a power problem with the radio stage, if it is only FM, check the antenna connection or you may have a problem in the Multiplex decoder circuit
If you can not solve it, I suggest you go to a specialized technical service
Hola Mark, pregunta, te hace esto con las estaciones de FM, como con las de AM?
Si es asi puedes tener un problema de alimentaci?n dela etapa de radio, si solamente es en FM , verifica la conexi?n de la antena o podr?as tener un problema en el circuito decodificador Multiplex
Sino logras resolver, te sugiero ir a un servicio t?cnico especializado
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Kenwood-KR-820-Service-Manual.pdf
Kenwood Audio... | Answered on Apr 24, 2019
Hello Kamran, your Kenwood, does not bring Dolby function, your high performance tape preamp works above the noise level that suppresses the Dolby
In this way, they avoid the use of Dolby and its Licenses
Hola Kamran, tu Kenwood, no trae funcion de Dolby, su preamplificador de cinta de alto rendimiento trabaja arriba del nivel de ruido que suprime el Dolby
De esta manera, evitan el uso de Dolby y sus Licencias
Popular Tags
5 questions posted
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Audio Players & Recorders
Most Popular Question
playing cd rw audio cds kenwood dp j2070
  • Audio Players & Recorders
