A very likely cause of this is an inlet solenoid water valve inside of the machine is leaking. The risk is if left unattended the water will over fill and end up on the floor. Secure the inlet valves where the hoses connect to the wall. Make sure that the valves are closed.
This repair requires an experienced technician to replace. The parts are readily available. To use the machine supervision of the wash process is required. The solenoid vales in the machine can not be trusted and you should assume that they may fail allowing water to overfill at an increased rate.
At this point when ever the machine is not in use the vales need to be closed. If the solenoid valve has leaked even once it can not be trusted.
