SOURCE: spin cycle
Rear shocks tend to wear faster than the front.
Try switching the front shocks to the rear. If this helps, plan on
buying 2 new ones. You will have time to search for the cheapest price... typically 25 USD @ /www.appliancepartspros.com/
SOURCE: How do I open my maytag Neptune MAH9700AWW front load washer?
first get access to the back of it. find the screws that hold the accsess panel on unscrew and look underneath. its on the bottom.
SOURCE: water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
SOURCE: Coin stuck in front loader washer
GO TO www.repairclinic.com IN THE BRANDS WINDOW CLICK ELECTROLUX THEN IN APPLIANCE TYPE CLICK WASHING MACHINE AND LOOK FOR PART 1154917 CLICK ON THAT PHOTO AND LOOK AT ADDITIONAL PICS.YOU WILL SEE THAT IT SNAPS INTO PLACE. FROM HERE I THINK YOU CAN TAKE IT OUT AND RETIEVE YOUR COIN. GOOD LUCK
SOURCE: coins stuck in washer
I've used a butter knife or putty knife to pry them up.. just enough to allow the coins to slide back out. Just roll the drum back and forth with the knife wedged in there. Good Luck.
