How do I get my washer to just soak the clothes without draining?
Occasionally I like to soak heavily soiled clothes. Whether I leave the lid up or let it run a few minutes and then lift the lid, I drains the water out.
Re: How do I get my washer to just soak the clothes...
The washing machine cannot operate at all with the lid up, unless the lid switch is stuck in the closed/on position. Draining water out when it should not is controlled by the circuit board of electronic components. Thus it is defective too.
9 WASH PERFORMANCE INFORMATION 9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet clothes to sit in the washer or laundry basket. 9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature according to soil type. For example, blood and mud are better washed in cold water, while sweat and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than soft water. 9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for the load can increase linting as there will not be enough detergent to hold the lint in suspension. Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the fabrics attracting lint. 9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times may not let the detergent dissolve properly. In these cases pre-dissolve the detergent. Overdosing of detergent can also cause residue when foam breaks down and will show as white specs on the clothing. Poor quality detergents can result in residue. 9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher powder and left to soak. 9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus detergent and left to soak. 9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes. 9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
WASH PERFORMANCE INFORMATION 12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
clothes to sit in the washer or laundry basket. 12.2 Soiling
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
soft water. 12.3 Linting
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
fabrics attracting lint. 12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
specs on the clothing. Poor quality detergents can result in residue. 12.5 Black Marks on Clothes
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak. 12.6 Grey Marks on Clothes
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak. 12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes. 12.8 Tangling
other. Do not load SmartDrive by wrapping clothes around the agitator.
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
There is no lint filters in these machines,
It is automatically pumped out with the drain water.
cycles have been designed to minimize creasing as they use a lower spin speed. Do not leave wet
than soft water.
9.3 Linting
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
after and hour off will it make it through the cycle? if so the motor could be over heating and shutting down. if not look and see if the pump turns freely and if there is an idler pully make sure it turns freely. check between tubs outer and inner for any sock or piece of clothing that could have went over the tub on a large lode and causing a resistance.check for a pinched off drain hose which will not allow it to drain. it has to drain to spin. or it will over heat pump. could be something caught in pump. try not to get wet,. done that alot when i had my business.
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Check drain in back of washer. Do not move the washer because the drain will straighten out and you will never know if that was the problem. Look behind washer with flashlight. Also pick up the drainhose out of washer drain pipe and watch the volume of water when its pumping. If its restricted the cycle will end before all the water is pumped out. Also Check lid switch, Raise top and splice the two wires on the lid switch together. If it runs thats the problem. Thanks for using fixya Leo Ponder imufo2 Please LEAVE TESTIMONIAL AND VOTE FOUR THUMBS UP FOR ME IF THIS WAS HELPFUL
