20 Most Recent Fisher and Paykel Aquasmart wl80t65c Questions & Answers
remove bowl and clean them both
Fisher and... | Answered on Apr 21, 2018
most likely a faulty lid lock unit
if its a top loader that is incorrect it mean machine needs resizing and if tht doesnt work a new main control module
most common problem is worn out suspension rods will need new set fitted
restricted pump or drain hose if all good them probably a faulty pump
this is all one unit hot and cold together sealed unit
put powder down inside agitator not do not sprinkle over clothes not remove top off agitator first
Fault code 49 is water valves - usually, the stop working when the rubber diaphagm inside gets hard, so a resistance only test is not conclusive (only tells us the solenoid is OK).
- Do a cold fill and a hot fill (briefly) to check for strong water flow on both.
- Regarding code 245, does water pump out strongly?
- One more thought, because these codes are both related to the water level in the machine, remove the level sensor hose at the controller end and blow into it to clear any blockage.
Fisher and... | Answered on Jan 31, 2018
Yes the shop you bought it from. At only 12 months old the warranty should still apply.
Fisher and... | Answered on Nov 07, 2017
Replace just the lid lock assembly to start with and see how it goes. Lids are quite expensive and don't usually need replacing. You can always get a lid later if you still have problems.
Fisher and... | Answered on Jun 21, 2016
Hi there..... mine did the same a couple of months ago, kept towels around, monitored, seemed to stop after some days (uses); Any update on yours ? Self-healed, Repairman, or Replaced ?
Fisher and... | Answered on May 09, 2016
Switch to Powdered Detergent and you wont have to clean your washer. Liquids leave a smelly, corrosive residue on the inside of the machine, use only Powder and leave the lid up when not in use to defeat the slime!
Fisher and... | Answered on May 04, 2016
Inside the drain pump. You can get to it by removing the spin bowl. Remove the 2 screws holding the pump cover & lift the cover off to expose the flapper valve.
Fisher and... | Answered on Dec 03, 2015
javascript:;To size set a L.C.D AquaSmartâ„¢ machine:
1. Press and hold the left
SCROLL
button, then press the
HIGH EFFICIENCY
button until two
beeps are heard.
2. Press the
SCROLL
button to select the machine size (600 for WL70, 650 for WL80).
3. Press the
POWER
button
Fisher and... | Answered on Apr 13, 2015
The black bits are scum flaking off from between the inner & outer bowls, usually more common with cold water wash. Place old towel in washer, fill washer to high level with hot water, add washing soda & or vinegar, let washer run to end of wash cycle, turn off & let it soak for around an hour, turn back on & let it go through cycle. Commercial washing machine cleaning products should also be availably in your supermarket / hardware stores. You may need to repeat process until no more gunk comes out.
Fisher and... | Answered on Feb 12, 2015
these are a common problem for AquaSmart machines.
Your AquaSmart machine requires 4 new suspension damper rods & 4 top bands,
Fisher and... | Answered on Dec 14, 2014
Your AquaSmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Have you run a "Clean Up" cycle - it is important to do this to ensure your clothes are clean and the machine works at it's peak. If you use it heavily, you should do this every three or four months. You can find this cycle under "Lifestyle" and you should put 1 cup of oxyaction soaker in at the beginning of the cycle and it needs hot water to work. It takes about 3 hours, but is well worth the time.
There is no other real reason for a smell, unless something has died - in which case you should move the machine and remove any deceased animal.
Fisher and... | Answered on Dec 03, 2014
Fisher and Paykel Aquasmart wl80t65c Logo
121 questions posted
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Washing Machines
Most Popular Question
fisher paykel top loading washing
  • Washing Machines
