SOURCE: LCT32HA36
Check the capaciotors in the power supply for bulging conditions.
Click here to have an idea how they might look like.
Good Luck.
SOURCE: Samsung FP-T5084 No picture
For a 50 inch plasma....its worth it, in my opinion y-boards cost around $149 to $189
Testimonial: "Thank you. your feedback was appreciated. Theres a lot of value in getting an expert opinion whether to fix or not to fix."
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
SOURCE: We have Samsung LCD model LN26A450C1D, which is
The tv Tuner board is dead,that the board,where the brocasting incomming signal cable connected into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Testimonial: "Thanks for quick response! I will try. "
SOURCE: I have a 46" Samsung LNT4661FX / XAA LCD TV. My
Good fixes. Sometimes the connector for the cables running from the LCD to the T-CON do not make good contact. You might try moving them around to see if it affects the picture. You can even carefully disconnect and reconnect them.
I have come across one person that fixed a display by resoldering as many joints as possible on the main board.
When these boards are made they use a wave solderer and with the new RoHs standards and shoddy workmanship a lot of 'cold joints' are developing. If you do this, use RoHs compliant solder.
