The E24 error code indicates no drain flow possible. This means that the drain pump is running but unable to remove the water, or drain system blockage. Check for blockage of drain hose and drain pump. ... We have replace the water intake valve and the water pump.
Hi Darlene, The link below is a bosh dishwasher error code AND how to fix, I hope this helped..........CHEERS.. Bosch Dishwasher Error Code E22
Fault Condition: Residual water in sump
Repair or Check: Check for a blocked pump, a dirty filter, or grease build up.
Parts Required: Pump or clean filter
You said you had water under the dishwasher,did you remove the lower panel below the door and check for water in the base frame as well. Bosch dishwashers have system in the base frame that detects water in base and cuts power off to every component except drain pump till it no longer sees the water in the base.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that will help you to find out why water will not come into the
dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
the spray arms are rotated by water coming out of angled jets, this water being forced round by the main circulating pump. suspect it may a fault with this pump
