I upload all the songs that I wanted..and it shows that they are all on it, but then when I turn on the player it only shows some of them.
I tryed deleting all of them and uploading them again, but it happened again! I tried that at least 6 times and it still does'nt work.
should I format it?
Help!
Sounds like you may have some corrupt files on the device.
Follow these steps to erase everything and start over.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Before you place your mp3 file in the folder, go to rightclick-properties. Click summary and make sure that each file has an Artist, Album, and Title before you put them in the folder.
SOURCE: Song is "Unknown"
If your using Windows XP right click on the MP3 and select properties. Then click on the Summary tab and select Advance. From here you will see a list of labels for your MP3 such as artist, title, year. album, genre and etc... When you edit it from here it should show on your Sansa. I hope this helps :-D!
SOURCE: sansa e250
You need to enable Hidden Files and Folders on your PC to see the MUSIC folder as it is hidden.
Best of Luck.
SOURCE: Phantom Songs on my Sansa e250
Use Windows Media Player to delete, or double-check the format of those songs
SOURCE: my sansa e250
If you want to delete EVERY track off the player, then reformat the player in Windows Media Player - it's a shortcut - see my "tips and tricks" on formatting mp3 players
If there are artist, album traces, then you need to click on every subfolder under your device in Windows Media Player and delete every trace that way - tedious, but effective
-Tha Mp3 Doctor
There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details
If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
SOURCE: how can i delete music file from my sansa e250
try formatting the player by selecting format from the properties menu when you right click it in my computer.
I did it. it did'nt work really...
