This occurs when you have a corrupt operating system or a bad hard drive. You will need to check the hard drive to see if it is still good and, if so, reinstall the operating system. If not, then you will need to replace the hard drive and the operating system.
And why did you give a bad rating? You asked a question and I gave you the answer, yet you gave a bad rating. Please come back and give an appropriate rating because this has nothing to do with the service packs as you suggested but is an indicator of a bad hard drive.
You can't post conmments that contain an email address.
Many
times this error occurs when I have swapped a hard drive and used the
wrong IDE cable to connect it. If your computer uses an Ultra Direct
Memory Access (UDMA) hard disk controller, and you use a standard
40-wire connector cable to connect the UDMA drive, you may experience
this error. Make sure you are using the correct IDE cable.
Also, if
your BIOS settings are configured to force the faster UDMA modes, this
error may occur. In this situation, restart your computer and enter the
BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
0xED is not just specifically present on HP computers but all PC-based computers which has XP or later using NTFS on it. It can be resolved by doing a chkdsk /f /r or by performing a repair installation using windows.
This is caused by software corruption (which is repairable using the steps aforementioned) or hardware failure, which may lead to OS reinstallation or harddrive replacement
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps. Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks 2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console 3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access 4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter 5) At the command prompt, type CHKDSK /R and then press Enter 6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
Hi everyone...my windows xp wouldn't start up at all..(unmountable boot volume).kept restarting with the blue screen...I had ** xp disk (came pre-installed)....finally was able to get to my files by downloading K**ppix to a CD and running that on my broken xp ...just downloaded it, ran it, and I was able to access all my folder/files that I didn't want to loose...**w I can use my recovery disks to get my computer running again..I would recommend this option to anyone with ** xp disk...it saved me from loosing important files that I needed...just thought I would share this with you since I k**w many pc's do NOT come with the windows disk these days....
