Some schools do not allow software to be installed on their computers so the U3 system will not work. You can turn off the U3 capability and just use it as a regular flashdrive.
Option A: 1. Plug it in. 2. My Computer > select Removable Disk (if this doesn't work chose option B)
I'm pretty sure that the Cruzer Micro has a software that needs to be installed on the computer to be able to access files.
Option B: 1. Plug it in. 2. My Computer > Open U3 System (this is the application installer for the flash drive. 3. after installing there should be a little icon on the bottom right of the screen thats orange and white click on it and it will pull up an interactive menu for your flash drive.
It either has a snap ring holding it on the shaft or is threaded so that pulling the chain will tighten it. Remove snag ring or use something to drive against the clutch in the direction opposite the normal travel. If it is threaded, you will have to jar it pretty good to break the threads loose
The school's Computer Systems Administrator may have installed a "Group Policy" setting that tells Windows to *NOT* allow USB-devices (iPod, iPad, flash-drives, external disk-drives) to be allowed to be used. It's a good way of preventing computer-viruses from getting onto the school's computers.
If your SanDisk works correctly on your own computer, then use your own computer.
Something is wrong. when higher currect flow through the circuit, that's when components get heated up. Either Stop using the flash drive or you may end up spoiling your Motherboard too.
this doesn't have anything to do with the computers; it's something schools and businesses set up on their networks. and it's not something you can change unless you can get admin access to their router(s).
sorry...
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
4x4 low is just alow ratio gear in transfer case just for when you need that extra boost when your stuck or pulling something up a hill or thru mudd, something on that order. you can run the transmission in any gear you want, but drive is the prefered gear. in other words when your in 4x4 low lieve it in drive. happy 4 wheeling. OLD SCHOOL.
