I need serial# to be able to get some parts,i dont know the year this product came with house. i could only see the model#FR26C7DS2 and the Serial# was torn off .Can you please help me with this matter? Sincerly, MM
SOURCE: Ice Maker Problem
change your water valves one is leaking just a drop at a time so you dont notice but over a period of time it builds up and blocks the tube
SOURCE: CLOG DRAIN FOR REFRIGERATOR
Hi, thanks for the question. these new ,or older fridges have the drain tube, between the walls of the fridge , and what happens is the water in that drain tube freezes. so the water in the defrost cycle ,cant go down to the drain pan. to repair fridge must be turned off. for at least 24 hrs. insert a small plastic tube, from the drain tray up to the freezer, an blow up the tube to clear. thanks the appliance doc. please rate my answer thanks..
SOURCE: fridge doesnt work both freezer and refrigerator part not making ice
TRY REPLACING OVERLOAD RELAY..PARTS #67005560....IT COST TO ORDER AT THE INTERNET AT $27.45..........REPAIR SERVICE WILL CHARGE YOU , AS WHAT THEY DID TO ME $69.43 PLUS $120.00 FOR LABOR....IT SUCKS.....FROM ALEX ESMENA ..NORTH LAS VEGAS NEVADA
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
SOURCE: frigidaire the refridgerator is not
Have one similar and found out the compressor goes out on them about a year and half after purchase. You can buy another compressor but the likely hood of it going out again is likely. Sorry but we bought bad fridges. Never again will I buy a Fridgidaire.
Hi L Martin - For this particular model FEX831CS0, the heating element part number is 131475320. The part may be purchase directly from the manufacturer or through a part distributor in your area.
Hi Michael Gallagher - I found the manual on the Frigidaire website which it is the sister company of Electrolux. Here is the manufacturer link and hope you find all the information that you need. I will recommend taking off the last letter of the model number so you can pull up the information.
http://b2b.frigidaire.com/support/manuals.asp?NewSearch=New+Search
