Amana D565e Dehumidifier Logo
D
Darlene Posted on Jun 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dehumidifier is no longer collecting water. Unit (and room) seem to be getting warm. Filter is clean. Everything seems to be running.
johnny rebel
Level 3:
Top Expert:
  • Amana Master 10,875 Answers
  • Posted on Jun 13, 2015
 johnny rebel
Amana Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2942558
Points
47944
Is it getting cool??if not it needs a thermostat or freon if the compressor still runs
1helpful
Runs but no longer collects water
In the price range, most of the comparable united are the same under the skin. I like whirlpool since replacement parts are widely available.
before you condemn the unit, check three airflow and the temperatures of the suction and discharge tubes a few inches from the compressor. If the discharge is hot and the suction is cold, the circuit is probably still whole.
Clean cooling coils. in the last week or so my dehumidifer in the basement seems less productive in collecting water, i have two down there and the other works - i have to empty it often, thats how i...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
2helpful
2answers
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
My DeLonghi DE500P dehumifier whch I purchased last fall is no longer collecting water. Everything seems to be functioning as outlined in the instructions. The rooms humidity is about 55%. Any ideas?
heatman101
1helpful
2answers
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
1helpful
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
1helpful
Runs but doesn't collect any water
1helpful
2answers
Unit runs but doesn't pull humidity out of room, filter clean
Possibly lost refrigerant from system- check warm air is coming out of machine. Otherwise it could be dirty filters, and not getting enough air over evaporating coil. Other than this, replacing parts is usually more expensive than buying a new dehumidifier :(
2helpful
2answers
LG45EL dehumidifier no longer collects water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
1helpful
Dehumidifier does not collect water.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Top Amana Dehumidifiers Experts
Paul Carew
NOEL
NOEL
Ron Jeremy
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
