No matter what setting is used on the unit, only the fan works. The only way I found to make it work...
(More)
No matter what setting is used on the unit, only the fan works. The only way I found to make it work is as follow: Put the Desired Humidity to Normal, remove the water bucket while unit is working. Then wait until the Empty/Adjust light comes on before putting back the bucket. Increase the humidity control to max dry or continuous. The compressor then starts. I find that this is not normal and might return the whole thing.
My Whirlpool model ad50usl3 runs but does not dehumidify. Bucket is bone dry and has been running...
(More)
My Whirlpool model ad50usl3 runs but does not dehumidify. Bucket is bone dry and has been running for 3 hours.
this unit is about 2 years old . It has been off since last fall. Started it up about 2 weeks ago....
(More)
this unit is about 2 years old . It has been off since last fall. Started it up about 2 weeks ago. fan is running at all settings but I don't think that the compressor is, because (despite a film of water on the floor of the basement) no condensate water is being discharged from the hose as in the past. I did clean the filter but with no apparent effect. Can someone help?
Service and Repair, System Maintenance, Advantage Mem... Read More
Service and Repair, System Maintenance, Advantage Member Plans, Replacement & Installation, Guarantees, Air Cleaning and Purification, Duct Sealing, Duct Cleaning, Indoor Air Quality, Heating, Air Conditioning and Indoor Air Quality Products, and Commercial Services for your business.
