Question about Amana D530M Dehumidifier
Why won't my dehumidifier collect water? It runs fine but never any water in the tank.
Posted by janayjones on
D. Floyd Kolb
  • Amana Master
  • 43,501 Answers
Here is a tip that will help you with basic trouble shooting..
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Posted on Apr 21, 2010
5 Related Answers
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: not working
Hate to tell you, but it may be a goner. Many units have a rectangular air filter that may be clogged, but I would still expect to see some moisture removal. Without exact model I'll have to be general,.... remove cover (front or back, depends on model) to see cooling coils. If the compressor is running, these coils should be wet or may have a light frost on them for a time. Not = refrigerant leak. (not economical to repair) If you see one small area of ice,... it's also a goner. If the compressor does not run you could have a bad compressor, a bad defrost control, or a bad control / humidistat. Other than the filter or possibly a fan motor, these unit are rarely economical to repair.
Posted on Aug 28, 2008
Marty marty
  • 883 Answers
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Posted on Jun 08, 2007
Anonymous
SOURCE: Dehumidifier does not collect water.
I had the same problem. I just narrowed it down to the humidistat by wrapping it in a baby wipe. It runs smooth now and fills the bucket....I'm off now looking for a replacement.
Posted on Aug 13, 2007
Anonymous
  • 104 Answers
SOURCE: dehumidifier runs without collecting water
1- check if the water collecting bucket is properly installed (the light will show is ON but if the bucket is not propely installed -pushed in the proper position ) -make sure the slots on the bottom of the dehumidifier are posisioned correctly.
Posted on Oct 04, 2008
Anonymous
SOURCE: I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Posted on Jun 12, 2009
The dehumidifier is on but the tank is not collecting any water.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 07, 2011 | DeLonghi DE500P Dehumidifier
No water being collected in the tank,, just fanning
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 21, 2011 | Danby DDR2509EE Dehumidifier
Unit shows green light for dehumidifying, but no water collects in tank. Dank smell in basement does not diminish
heatman101
Feb 09, 2011 | DeLonghi DE40P Dehumidifier
Dehumidifier does not remove water from the air.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 31, 2010 | Maytag M7DH45B2A Dehumidifier
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
Problem with haier hd306 dehumidifier
heatman101
Oct 02, 2009 | Haier HDN655E Dehumidifier
Amana D530M Dehumidifier Logo
3,432 people viewed this question
Top Amana Dehumidifiers Experts
NOEL
NOEL
Tom Chichester
Terry
Terry
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
