When i on the MX-M264n sharp the message is appear in screen 'Err:Failed to expand ARM9 Prg. Pls sir help me out what should i do. waiting for ur reply
Have a tech come out and reflash the firmware
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: error in sharp am900
Hi, I just experienced the same problem and realize the reason my msg of "CHK SCANNER LOCK/PLS RETURN POWER" was because I had to many things plugged in the same power outlet (computer, tv, printer, internet)... when i turned off the tv (the machine worked fine). hope this helps
SOURCE: I have a Sharp MX-M264N and my alignment is off.
In the copier mode use a testchart if the copy is OK your problem is the printer settings.
