SOURCE: briggs 98902 carburettor spring diagram
Go to Briggs & Stratton on the web and pull up the diagram.
SOURCE: adjusting governor/throttle briggs and stratton
there should be a little screw to help adjust your idle try that..counterclockwise to add more idle, clockwise to slow idle..
SOURCE: Briggs and stratton 35 classic. Need piccy of
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
The accelerator pedal
The accelerator pedal position (APP) sensor 1
The APP sensor 2
The throttle body assembly includes the following components:
The throttle position (TP) sensor 1
The TP sensor 2
The throttle actuator motor
The throttle plate
The engine control module (ECM)
The ECM monitors the driver demand for acceleration with 2 APP sensors. The APP sensor 1 signal voltage range is from about 0.98-4.16 volts as the accelerator pedal is moved from the rest pedal position to the full pedal travel position. The APP sensor 2 range is from about 0.49-2.08 volts as the accelerator pedal is moved from the rest pedal position to the full pedal travel position. The ECM processes this information along with other sensor inputs to command the throttle plate to a certain position.
The throttle plate is controlled with a direct current motor called a throttle actuator control motor. The ECM can move this motor in the forward or reverse direction by controlling battery voltage and/or ground to 2 internal drivers. The throttle plate is held at a 7 percent rest position using a constant force return spring. This spring holds the throttle plate to the rest position when there is no current flowing to the actuator motor.
The ECM monitors the throttle plate angle with 2 TP sensors. The TP sensor 1 signal voltage range is from about 4.86-0.86 volts as the throttle plate is moved from 0 percent to wide open throttle (WOT). The TP sensor 2 voltage range is from about 0.82-4.14 volts as the throttle plate is moved from 0 percent to WOT.
The ECM performs diagnostics that monitor the voltage levels of both APP sensors, both TP sensors, and the throttle actuator control motor circuit. It also monitors the spring return rate of both return springs that are housed internal to the throttle body assembly. These diagnostics are performed at different times based on whether the engine is running, not running, or whether the ECM is currently in a throttle body relearn procedure.
Every ignition cycle, the ECM performs a quick throttle return spring test to make sure the throttle plate can return to the 7 percent rest position from the 0 percent position. This is to ensure that the throttle plate can be brought to the rest position in case of an actuator motor circuit failure. Observe, under cold conditions, the ECM commands the throttle plate to 7 percent with the ignition ON and the engine OFF to release any ice that may have formed on the throttle plate.
The APP sensor 2
The TP sensor 2
The throttle plate
The ECM monitors the throttle plate angle with 2 TP sensors. The TP sensor 1 signal voltage range is from about 0.5-4.25 volts as the throttle plate is moved from 0 percent to wide open throttle (WOT). The TP sensor 2 voltage range is from about 4.45-0.7 volts as the throttle plate is moved from 0 percent to WOT.
