20 Most Recent
Husqvarna 128 LD Weedeater Questions & Answers
How do I replace a flexshaft on my huqvarna 128 LD
I have a Husqvarna 128LD and love it. When using a tiller attachment the part of the shaft that has the knob comes loose. I have tightened the screw with allen wrench but it still comes off. or gets loose. Can I weld the bracket to the shaft?
Rebuild the throttle housing to a 128ld
Not sure if you are asking about the throttle assembly or carb. Both of these are available as kits from Husqvarna and will save you a big headache trying to rebuild.
How to change the fuel lines in the 128 Ld Husqvarna Trimmer
Buy some new fuel line then put the line in from the motor side into the tank and feed up and through the opening on the tank. Then you can put on a new filter with a tiny clamp then put it back into the tank making sure the filter is resting on the bottom.
