20 Most Recent Husqvarna 450 e-series 18" Chain Saw Questions & Answers
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Husqvarna 450... | Answered on Sep 30, 2018
Hi. Beside where the fuel line go through there should be a small nut with a spring beneath it. Turn that slightly to allow more fuel through. ONLY DO IT A FRACTION AT A TIME.
Husqvarna 450... | Answered on Oct 15, 2017
450 does not have a cylinder head. The cylinder assembly is one piece. The cylinder assembly is connected by 4 bolts installed from the bottom of the saw.
Husqvarna 450... | Answered on Feb 03, 2016
Check to see if the primer is split or leaking. Then check your fuel filter and fuel lines. If all are clear and no leaks, the only other issue would be carburetor or lines installed incorrectly.
There is not much wiring on the 460. The coil has the lead to the sparkplug, then there is the ground (kill) wire running to the switch and grounded to the engine.
The adjustment handle snaps down to lock. If the handle is coming loose, I recommend replacing the handle. You can also go to standard bar bolt set up if you prefer. Check with your Husqvarna dealer for part numbers.
Husqvarna 450... | Answered on Jan 15, 2016
Pretty sure it is 50:1. You can check right at your Hardware BOX store on line to verify that. The "Blue" one in the US especially.
Husqvarna 450... | Answered on Nov 06, 2015
check oil pump, oil pump drive gear, and rubber oil guide tube isnt blocked
Husqvarna 450... | Answered on Mar 07, 2015
ask husqvarna Sweden ( the can answere you in your language
Husqvarna 450... | Answered on Jan 21, 2015
you tube has video's on how to do this
Husqvarna 450... | Answered on Dec 01, 2014
The primary jet is probably clogged. If you remove the fuel bowl and float assembly you should be able to slide a fine wire through the orifice to clean it. Rinse everything with carb cleaner before reassembly.
Husqvarna 450... | Answered on Nov 25, 2014
If the choke is not fully opening, that would cause this problem
check this first.
Husqvarna 450... | Answered on Aug 14, 2014
The grey plug in the base of the oil tank is the oil filter it will twist 1/4 turn and pull out, to replace push back in and turn 1/4 turn there is a leg on it that locks into the orange tank, there is a screw driver slot in it to assist this, they can be really tight try not to force too much or you will break it.
Husqvarna 450... | Answered on Apr 30, 2014
the oiler is not adjustbale.
Husqvarna 450... | Answered on Apr 10, 2014
chain oil is not ajustable. the pump is most likely faulty or the oil ports blocked.
Husqvarna 450 e-series 18" Chain Saw Logo
138 questions posted
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
450 husqvarna chainsaw primer bulb
  • Garden
