Handset shows fully charged but won't turn on. Answering machine still works.
SOURCE: Handset Buttons Stopped Working - Full Battery
Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
Hope this helps.
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
SOURCE: I have the Uniden TRU9085-3 Series (base answering
to clear the base of all phones. Missing or not. for the uniden tru9085 3 cordless phone
First deregister any phones that you already have. You can do it by linking to the base, or you can do the 'remove battery, press key, insert battery' method.
Once that is done:
1. Disconnect ac adapter
2. Press hold dnd ,middle soft key, star key, hold at the same time.
3. Reconnect ac adapter while holding three keys
4. Long beep release button
Done!
SOURCE: why is handset reading out
THAT HAPPENS WHEN YOU DROP THE PHONE TOO MUCH.
THE SOLUTION IS TO TURN OF THE BASE FOR 2 MINUTES.
THEN REMOVE ALL THE PHONE BATTERIES. ALL OF THEM
WAIT FOR MINUTES,
PUT THE BASE BACK FIRST, PUT ALL OF THE PHONES BATTERY BACK
PRESS THE RED BUTTON, YOU WILL SEE THE "OUT OF RANGE RANGE" MESSAGE AGAIN.
IGNORE IT AND PRESS THE GREEN BUTTON. HERE YOU GO.
MAKE SURE TO CHARGE IT AFTER THIS.
PLEASE RATE IF THIS SOLVED YOUR PROBLEM
