KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
Bennie Durham Posted on Apr 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Kitchenaid Artisan 5qt stand mixer that sparks and kicks the breaker when switched on. I removed the ground. Now, it comes on when plugged in, even when the switch is in the off position.
MendingShed.com
Level 2:
Novelist:
Scholar:
  • KitchenAid Expert 134 Answers
  • Posted on Apr 24, 2015
MendingShed.com
KitchenAid Expert
Level 2:
Novelist:
Scholar:
Answers
134
Questions
0
Helped
109205
Points
435
I agree in a wiring situation a KitchenAid Service center is the best place to go to, here is a link to KitchenAid's service center locator: SERVICE LOCATOR However a lot of areas do not have service centers and if you call KitchenAid 90% of the time they will send you to us (The Mending Shed) as we are one of the only service centers that not only works on these mixers every day but we will actually take the time to help you diagnose the mixer and repair it correctly.
It does sound like you have a short to ground. The answer is definitely not taking the ground wire off, so put that back into place. Remove your end cover and look at the speed control plate make sure you do not have any loose wires. If you do not see anything then most likely one of the wires that come off of your field and connect to the brush holder has come loose and is shorting out. The kitchenAid service manual has a full wiring diagram and instructions on how to check the wiring in the mixer. Here is a link to the service manual: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf The last page of the service center is where you will find the wiring diagram.
Once you have corrected the wiring check you speed control lever and link (also found in the service manual about page 7) and make sure that the speed control link is positioned correctly so that the mixer will shut off when set to the off position.
If you need any help please feel free to call or chat with us and we will help you the best we can so you can get your KitchenAid mixer back up and running.
- Colleen @ The Mending Shed
Ross Keen
Level 3:
  • KitchenAid Master 1,365 Answers
  • Posted on Apr 09, 2015
Ross Keen
KitchenAid Master
Level 3:
Answers
1365
Questions
0
Helped
583527
Points
2445
Please unplug it and leave it alone. The earth wire is a life saving device put there to stop you killing yourself if something goes wrong. It is not a little green wire that you can remove on a whim even if just for testing purposes. Your mixer is unsafe if plugged in without it.
The fault is unlikely to be a big deal as far as expense goes, a proper service agent will be able to locate the fault using their eyes and a multi meter. I would be looking for broken or partly detached wiring inside, maybe even insulation worn through somewhere.
Phone Kitchen Aid and ask who your local service agent is.
The Kitchenaid Artisan stand mixer is spinning too fast after a voltage fluctuation.
Replace the phase board, that's the small pcb under the back cover with 6 wires coming out of it.
1helpful
My Kitchenaid Mixer Model KSM150Ps is tripping my breaker after replacing the speed control board.
Try a different Receptacle outlet if it trips that breaker you know its the mixer, and there will prob be a short/loose connection somewhere
My daughter's Kitchenaid Artisan 325 watt mixer had a malfunction last night. The unit itself is less than 3 years old. It had been running on high for approximately 5 minutes when sparks began to fly...
Sorry cant solve this but mine did the same. Mine is almost 4 years old now. Have you found out what the problem was with yours? Have you sent it back? Nicky.
1helpful
Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
1helpful
2answers
Kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
4helpful
2answers
KitchenAid Artisan KSM150BOB Stand Mixer won't start
It could be very easy. It maybe you have a the brush in the wrong way round or they have simply run out. They are on the sides under the black plastic caps. Although they will fit in the hole any one of 4 ways round, there is a key on one corner which means it will only go in one direction. Use a torch to look into the hole before you put it back in.
They shoud look like this : brush
KitchenAid Artisan Stand Mixer missing plug/where is outlet?
I can only imagine you have a shop display machine and they took the plug off. Otherwise it should be obvious.
Kitchen aid artisan speed control stuck
Hiya,
Sorry you are experiencing an issue with your appliance. We have some help videos to assist you with resolving this issue. Please see one of the links below for your perusal.
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidMixerHelp/Howtoreplacethespeedlever/tabid/643/Default.aspx
https://www.youtube.com/watch?v=y97KT98vpJ0
To purchase new speed lever, please see the below link:
9709276 KitchenAid Tilt Head Stand Mixer Part (also 5qt bowl lift) Speed Lever Black https://secure.kaparts.co.uk/sku/9709276
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
