I have taken it apart and placed the brass valve in descaler with no changes.
SOURCE: delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
SOURCE: need to replace steam valve on delonghi magnifica coffee machine
the steam valve will pop off it comes straight out
SOURCE: DeLonghi Esclusivo Magnifica ESAM3300 Espresso
Hello, you can buy descaling tablets at your local Starbucks. There is also a liquid descaling solution (small bottles) you can buy anywhere.
At the moment I'm using Jura brand descaling tablets I purchased at Starbucks. For instructions on how to descale (quite simple really), see here on p-17 at:
http://www.starbucksstore.com/images/products/pdf/DeLonghi_Magnifica.pdf
Hope this helps.
SOURCE: Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
