Televison & Video Logo
K
Kathy Bushbaum Posted on Mar 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to disable parental control so a password does not have to be entered every time the tv is turned on
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Mar 30, 2015
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007879
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
1helpful
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
1helpful
4answers
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
2answers
How to use parental control
You can enable customize Parental Controls via your TV's on screen menu. If you have previously set a password, you will need to re-enter your password to begin. If you have forgotten your password, try 0000 (four zeros) or 3448 (the default password may vary by TV model, so consult your User Manual for details). You can find detailed instructions for using the parental controls in your TV User Manual, available for download at InsigniaProducts.com. Just search for your TV model number and click on the Support/Download tab. I hope this helps.
How to disable the parental control lock for Insignia NS-Lcd19? I never enabled the pc and have not had this problem before-tv 3yrs old. Please help. I checked the manual and followed the instructions...
If you have never set a password for the Parental Controls, enter 0000 (four zeros). If you set a password (or believe one was set accidentally), use password 3448. You should then be able to change or disable the controls. If these steps do not work as your message indicates, your TV may require repairs. Service can be obtained by carrying the unit in to the place of purchase.
6helpful
I have a philips magnavox ms2730 c tv 27 inch , my parental lock is enable but i didnt enable it and i cant get it turned off, i was hopping i couldnt find a default password .
I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set).
Philips sets use 0711 as the override code to defeat parent lock. You may need to enter the code twice if it says "invalid code" the first time.
Using the remote control:
Press the MENU key. Scroll up or down until you reach AUTOLOCK or SMARTLOCK. Press the "right arrow" key. Enter code 0711. Enter it again if it says invalid code.
Once in the AUTOLOCK or SMARTLOCK menu:
Scroll to BLOCK. Press the "right arrow" key. Scroll to BLOCKING OPTIONS. Press the "right arrow" key. Scroll to MASTER DISABLE. Press the "right arrow" key. This should unlock the parental control.
Hope this works for you. Thanks for using Fixya!
1helpful
Parental Control Code?
if you forgot your password you can reset it ,turn tv off press and hold vol< on tv and clear on the remote for 5 sec.,enter a new password next time you access the parental control menu.
6helpful
2answers
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
V chip password
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
2helpful
Parental control
  1. From the XBOX dashboard screen, go to settings and then parental control.
  2. When prompted for the password, perform the following sequence using the XBOX controller: X, Y, Left Trigger, X.
  3. Enter in a new password, or disable parental control entirely.
2answers
Parental block
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
