It shows no signs of function. I tried other outlets. Still no lights, no clicking, etc. There was no bumping or bouncing Just moved from one place to the next.
SOURCE: RGBPC input showing invalid format after move
There is nothing wrong with the connection, your TV or computer. Just changw the resolution settings under the display properties. Start with the lowest setting 800X600 and move your way up. It will eventually appear.
SOURCE: Hi. My Philips flat TV will not show any picture
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
SOURCE: Just brought home my 47PFL7403D/F7 that was a
If SAM gave you the Philips universal remote without programming it for your TV, you should request the remote that come with the TV. Does the remote look like this?
http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=Philips+47PFL7403D+&uuid=12574802642290
SOURCE: how do i watch movies on a philips 42pfl5603d/f7 from flash drive
the flash drive connection is usually for viewing pictures, but in most cases its used to upgrade the tv
SOURCE: My Magnavox 17in LCD TV (17MF200V/17) shows
I have a Magnavox 32'' LCD, the main menu keeps displaying on the screen. When I try to exit, it exits for a second then come back. Does anyone know how to exit this annoying menu??? I called Magnavox tech support, they told me they are not sure and my LCD TV is more than 1 year old, I don't have extended warranty so they can not help me.
