Flywheel for automatic transmission.
Go google and type in - torque settings for (your engine as you haven't given that infomation) and there will be pages of details
There is no flywheel for an automatic. What you have is a flex plate as the torque converter acts as a flywheel
and what does the starter engage if not a flywheel
the starter motor pinion engages with w ring gear which is welded to a flexi plate ( a round disc of spring steel plate) that is attached to the end of the crank shaft. The torque converter is attached to that plate with either 3 or 4 short studs. It is a flex plate and not a flywheel
