On most dishwashers you would hook up the hot water line. Most folks assume because the unit has a heating element that it will heat the water. I have found that's not the case. The element is there to dry the dishes
Hi Charles
The traditional method of supply was using hot water for filling. However, it is possible to save money on some machines by hooking up to cold water as the element in the dishwasher uses less power than your water heater. Unfortunately, some manufacturers still require using hot water for filling. You'll need to check your manual to see if this is the case. Here's a link to This Old House explaining dishwasher installation.
Hope this helps
-Steve
How to Install Dishwasher
