20 Most Recent
Hotpoint WMA58 Front Load Washer Questions & Answers
Water is not heating
hi u can put multmeter across heater you should get reading around 27on meter or close its been a while since ive done one
Hotpoint aquaius does not spin
Possible there is no power switched from the controller unit , You need to use a meter to check the output to the motor or else the timer panel is faulty. Also If there is power and the motor does not spin then it can be fault in the motor or the capacitor or FRICTION on the drive.
Where is the filter is
The filter is located at the rear of the washer.
Remove lower rear cover.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Please rate my solution.
Thankyou.
