What is the problem after i have replaced the bulb in my samsung dlp tv model hl-s46765. it tries to turn briefly then turns off and i get the lamp and temp/standby light blinking any ideas
I have replaced the bulb in my samsung dlp tv model hl-s46765. it tries to turn briefly then turns off and i get the lamp and temp/standby light blinking any ideas
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
One of the display blinking lights?It said bulb or lamp?If yes,ur projection bulb need it replaced,it life exspan,it over.It require a new projection bulb.
Sounds more like the TV is overheating. The lamp cooling fan may be seized or not spinning fast enough. If the TV gets hot enough to trip the thermal, it could rupture the lamp.
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Did you use an original replacement lamp or an aftermarket replacement? From the price you give, it sounds like an aftermarket lamp, which are notoriously buggy and the problem may be with the lamp. If not, the lamp driver is your next likely culprit. It is also called a lamp power supply or lamp ballast.
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
