For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
Hi. That's bad news of course. It may be that the color saturation is all the way down, or there is a fault in the TV.
Without remote, you might have a chance, if there is a button on the TV where you choose the +/- function (what is does). Standard is volume +/-. By pressing this extra button, you might get into other
settings. Like contrast, brightness, colour .
When no button with that function is availabel, you should by a replacement remote. Or better, an original one, as most of these replacements have problems getting into setup menu's.
Good luck anyway.
Sony DVD remote control have no set-up codes to Sinotec.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
Check the power supply.If you have no output from the power supply try to disconnect the power supply from the other circuits ( such as the IF,audio,video,horizontal,vertical,etc.If the voltage at the power supply comes up when you disconnect a particular circuit then that circuit is loading down the power supply and you would troubleshoot that circuit.If after disconnecting the other circuits and the power supply still shows zero,then you would troubleshoot the power supply.
