That indicates a drain error. You may have something hard caught into the impeller of the drain pump, or your might have a bad ECS sensor causing that (false) error code.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
SOURCE: Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
SOURCE: Flashing "Washing" light on my frigidaire 1000 series dishwasher
Possible solution. I had the same problem of "washing" light flashing last year and now today. Warranty has been expired for awhile, so no harm in trying. What worked for my situation was removing the six screws for the back of the plastic control cover. Take of the plastic cover. There are are two connectors to the HANDLE with white and black wires. To be safe I would shut off the ciruit to the dishwasher. Safety first. Carefully disconnect and inspect the contacts inside the connectors. Do not insert any metal objects if you left the power on. I believe that the moisture from the dishwasher can degrade the connectivity. I cleaned the contacts with q-tips and re-installed. Be careful to not bend the contacts. If you had sound, you could hear my dishwasher running. Total cost is about three cents. I believe that the connectors do not full close when corroded, which prevents the completion of the circuit to the controlls. The flashing light indicates that the door is open, when in fact it is closed. Hopefully this will help someone. Semper Fi
SOURCE: After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
