Question about Samsung DMT300RFS Builtin Dishwasher
Samsung DMT300RFS dishwasher; low-level water error
Low level water error comes up. Manual solution: with the dishwasher empty, add detergent and then run accycle. i've don it. It worked on one load. the same error came up on the next load however. Any sugestions greatly appreciated. Thank you Peter C.
Posted by Peter Chomiak on
  • 1 more comment
  • Anonymous Mar 16, 2014
    low water level
    low water level
  • Sterling Forest
    Sterling Forest Apr 04, 2017
    dnmtsn has the best answer on this page. It's pretty involved, but most likely the culprit. If your DW was ever upside-down, had a chance to grow mould, or developed some current between the water-sensing electrodes because of hard water, it will think the dishwasher is flooding and immediately drain.
spucketts
    New Friend:
A Samsung service tech showed me how to fix this one. You can take that float and the white box apart from the dishwasher and once opened, if its like mine, there will be gunk on the float and in the box at the line where it fills with water. This gunk floats in there and prevents the float from swinging and activating the switch. Just clean that gunk out with a toothbrush, I end up doing mine about once every four months, and it should work fine again. This tech said to prevent this, make sure the water is hot at the beginning of the cycle and pre-rinse the dishes-but this doesn't seem to work with mine.
Posted on Jul 25, 2012
  • 4 more comments
  • Chuckles Mar 26, 2013
    Where is the float valve located in the Samsung DMT300?
  • jeremiahburt
    jeremiahburt Apr 01, 2013
    How do you take the darn flow control off? On mine it's attached to a white plastic water intake piece.
  • DYIJon Apr 18, 2013
    no float valve on a DMT300RFS, it has a flow meter
  • Diane Meistad May 17, 2013
    What can you do if it's a flow meter? We too have this issue with our DMT300RFS. Purchased 14 mo. ago.
  • Dave Ross Oct 01, 2013
    I was able to get to the float mechanism and played with it long enough to get it moving freely. but couldn't figure out how to take it out to properly clean it. Is there a trick to this?
  • Cary D
    Cary D Dec 20, 2013
    Dave, there must be. This is the third time we have had the same problem with this Samsung. I can't figure out how to get the tank off to clean it. Last Samsung that I'll ever buy.
kellik5355
    New Friend:
I did exactly what was said in the first post and it worked like a charm. There were a lot of screws but if I had to pay a service guy to clean my machine I would have been mad at myself. Thank you, you solved an issue that has been angering me for weeks
Posted on Mar 30, 2013
Todd Peters
    New Friend:
Check under the strainer by unscrewing all screws and then pulling it up and out. I found 3 juice box straws to be the problem!
Posted on Feb 08, 2015
  • Dave Vermullen
    Dave Vermullen Feb 29, 2016
    Cleaning got it running again. Don't know why there are so many screws down there, but once they're out, cleaning was a breeze. She's running great so far. Will keep the float cleaning tip in mind for the future. Thanks all!
5 Related Answers
Anonymous
SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom. 366571e.jpg
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working. 677e4ea.jpg
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
Posted on Sep 21, 2010
fourfords
SOURCE: Low water level error with
Do you hear the washer draining (into the sink drain) after it fills and should start washing? Check that nothing (sound deadener, etc.) is interferring with the drain valve lever arm.
Posted on Feb 08, 2011
A Miller
  • 8404 Answers
SOURCE: The dishwasher detergent box is not springing open
This is brand new? Simple. Call the salesman and tell him the trouble. It is covered under warranty. If you fool with it you will void the warranty.
Posted on Sep 19, 2011
Jeffrey Bender
SOURCE: i have a samsung dmt300
I would remove and examine the wash arms to see if any of the holes are plugged with food or mineral deposits. Clear any food with a paper clip. If you have mineral deposits, remove the deposits with Lime Away or CLR cleaner. Hope this helps you.
Posted on Sep 16, 2011
chanisco17
  • 3 Answers
SOURCE: I have a DMT300rfw samsung dishwasher. The other
I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
Posted on Feb 06, 2012
Dishwasher starts and then stops with 9E flashing in window.
The 9E issue indicates a low water level in the dishwasher. Check your hoses. Make sure that no dishes flipped and filled with water. Make sure that the dishwasher is level. Next check if there is any debris blocking the water level (overflow) sensor. It's in a small square plastic box on the left side of the dishwasher. Pull the dishwasher forward and check for loose or damaged wires to the water level sensor.
If the wiring is good and the error persists, replace the sensor. Replace the wiring if it is damaged. If you add a comment with the model number, I may be able to point you to the replacement part. If your dishwasher is under warranty, contact Samsung for the repair.
I hope this helps.
Jul 04, 2016 | Samsung Dishwashers
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
How do you get to the float sensor to clean it on dmt3000rfb
might be the moisture sensor nxt to the float. They are both located on the left side where the fill tank connects to the outer side of the tub. It requires removing the unit, turning it upsde down, and opening some framework to get to it. there are instructions on the low-level sensor error page here somewhere.
Jul 02, 2014 | Samsung DMT300RFS Builtin Dishwasher
How do you fix the samsung dishwasher dmt300rss low water sensor
First be sure to disconnect/shut off water and power before beginning. Facing the washer pull it out. On the left side, outside, low, there is the water level sensor. It gets gunked up and trigger lever gets stuck. Clean it out and you will be good to go.
May 29, 2014 | Samsung DMT300RFS Builtin Dishwasher
Where is the water level switch located on the Samsung 300 series dishwasher?
There is an anti-flood valve on the bottom looking like an upside down teacup.
Aug 26, 2013 | Samsung DMT300RFS Builtin Dishwasher
Low water level
I have a Samsung DMT400RHS and I started getting the low water level error ('Normal'+Heavy'+Smart Auto' LED blinking). The error started intermittently a few weeks ago, but the the last day or two the problem was solid, and simply restarting the cycle no longer worked.
I looked of the code in the dishwasher user guide and it said 'low water level.' Searched the internet and located the repair manual at tradebit.com for $15. The manual was well worth the $15.
The manual suggested: 1) loose level sensor connector 2) Faulty Assy case sensor or stuck floater aka 'remove foreign matter' 3) Bad Main PBA assy.
Since we do 10+ loads a week for the last 18 months the stuck floater seemed to be the most likely cause.
Go to Samsung DMT400RHS Low Water Level Error ('Normal'+Heavy'+Smart Auto' LED) (new link is https://photos.google.com/album/AF1QipNtp1neOR7icVG8cSs71bLpxQD5k_xljiWcJD2P click the i on each picture to see the caption - DM 04/17/2016) to see the pictures and read the captions documenting what I did. Do this at your own risk. You must turn off and disconnect the electric power and turn off the water supply before you begin.
Jul 24, 2013 | Samsung DMT400RHS Builtin Dishwasher
Low-level water level error DMT400RHS
We took off the left side bottom and the float was stuck on ours. We bumped on it on the very bottom plastic while it was feeling up with water and the float flew up and now its working. We gonna let it run its course then clean it out where float is to make sure it doesnt have any more residue or gunk in it.
Sep 26, 2012 | Samsung DMT400RHS Builtin Dishwasher
What is the part number for the water level switch
Hello Kevin,
the part number for that water level switch which is called the flow meter or flow sensor is DD32-00004A
i dont know if your local appliance parts store carries Samsung parts but it could be ordered online at searspartsdirect.com,repairclinic.com
GENE
Nov 07, 2011 | Samsung DMT300RFS Builtin Dishwasher
Low water pressure
Is the hot water faucet under the sink open all the way?
Miss Midget
Nov 02, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Samsung DMT300RFS Builtin Dishwasher Logo
20,069 people viewed this question
Top Samsung Dishwashers Experts
Marvin
Marvin
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
