Check out the door switch to make sure that it closes when you latch the front door. If it does not close the machine will be inoperative - safety measure.
There is next to no adjustments so if the door dropped then the hinge must be bent . You may be able to very gently pull up on the door and re-align it but most likely you will have to replace the hinge.
no the impellar can not be reattached i will not hold and will come off again.I have tried to repair them before and they just do not hold. so you do have to replace the whole pump.
Replace the door switch, but,..... if you order the switch, they may send the switch in a rather large and heavy (and somewhat expensive) box which also contains the lower counter balance for the front of the drum. The reason is that on some machines, the counter balance is shapped in such a way that on certain off balance loads, the counter balance is able to strike the door switch and break it. The new counter balance weight has been re-designed to prevent this from occuring.
hello mam
after taking the water to its drum to a given level it should start the thumble wash and if it wont then we should check the timer switch,motor,and the water level controler.so please call the engineer.
usually switching off at the mains and the machine and waiting for a few minutes should do it. Make sure the programme select dial is at the correct position. Have you tried emptying out the water first? (either by putting it on a spin cycle or physically removing the outlet hose from the pump and catching the water in a basin or bucket)
