Freezers Logo
A
Anonymous Posted on Feb 12, 2015
I have a Frigidaire freezer that is about 5 years old. I get ice build up inside the top of the door. The door appears to be closed.
I have had a service man out because I thought perhaps the seal needs to be replaced. He did not seem to think that the seal needs replacement. He asked about whether the motor runs and I confirmed that it is.
Peter Goodwin
Level 3:
  • Frigidaire Master 744 Answers
  • Posted on Feb 12, 2015
Peter Goodwin
Frigidaire Master
Level 3:
Answers
744
Questions
Helped
366430
Points
2777
Hello;
My name is Peter. I am a retired field service refrigeration technician.
1.) Due you have the freezer in your garage? Freezers and refrigerators are not designed for the drastic temperature change through the seasons. If you had a service contract, your contract would be canceled.
2.) If you can run a piece of paper between the top door gasket and the freezer body you do not have a tight seal. Repair - Recondition the gasket. Wet the door gasket with water, with a hairy dryer heat the gasket while genteelly pulling the gasket out to expand with a spatula.
3.) If the gasket is good, then you are getting moisture either thru the top front of the unit or the top of the door.
a.) Inspect the liner where the ice build-up is. Are there cracks? Repair - Seal cracks with a good silicone adhesive.
b.) Inspect the upper door section and the front top of the freezer for possible leaks in the joints. Here again seal with adhesive.
c.) If the top of the door is expanded, then you have moisture in the door and need to replace the door. You will never get the moisture out of the insulating material.
Why is the top of freezer frosting up
The door gasket is leaking around the top of the door. Air getting in past the gasket condenses in the freezer causing the ice build-up.
Sep 07, 2014 • Freezers
My frigidaire automatic defrost upright freezer gets ice build-up at the top right at the front any suuggestions
This is just a general answer but it may mean that the door seal is leaking. Try running a dollar bill under the seal to see if that area is looser than the rest of the door seal.
Look inside the freezer for model number.
How to Check Freezer Door Seal DoItYourself com
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
1helpful
My Frigidaire up-right freezer used to make a sound when you closed it that sounded like the air was being drawn out. It doesn't make that sound anymore and there is ice building up at the top of the door....
either you need to put spacers under the door on the door pin to raise it up.you may need to bend the doon. or replace the door gasket
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
1helpful
I am experiencing frost build up on the top part of the door as well as the top part of the inside of the freezer. all other areas are fine
You have an air leak. Usually right where you frost build up is, however since hot air rises, sometimes this leak can be anywhere. Make sure your door closes tightly and your gaskets are clean and making good contact. You may have to adjust the gasket, adjust the door, or replace the door gasket. If there is ice on the floor of the freezer, you have a plugged drain line. In very rare instances we have found, where the freon lines enter the freezer, in the back or under the freezer, missing or fallen refrigeration putty that seals around the lines. Good Luck, Appliance Specialists
2answers
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
1helpful
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
2helpful
2answers
Ice build-up on the inside top of of freezer door
yea def , not normal, nor an acceptable amount of ice forming there( good pic). heres what i have been told to try and with good results
first make sure the door gasket is sealing all the way,(small gaps in ht emagnets at extreme corners) is common but with a little amount of "mortite"or "permagum can sometimes be insterted behind the corner of gasket to assist filling the void.
second a small amound of a white/clear silicone be applied to the outer perimtere of gasket, to minmize air movemnt from between gasket and door panel.
lastley in oyour second pic i see "frost free" written on a plastic air deflector. you can remove that with 3-4 screws on backside of it, and then reinstall with a small spacer so as the baffle now with sit with a 3/8in. gap between it and the top of the freezer liner.( a brass ferrel from the compression fitting of a plumbing fitting is just the right size)..... the theory behind this is to prevent the air from gatting "trapped" in the void created when the door closes-- air can now pass back and forth freely.
I hope this gives you some satisfaction if not I would advise another tech be sent who is willing to call for factore tech support( ths is where i got my info from)
Top of freezer thawing
Ice build-up in the area of the door could be causing the door gaskets to loose their seal. Shut the unit off and use a hair drier to melt the ice away from the door area. Return the control to run position and see if it makes a difference.
2answers
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
