Please help! When debugging Visual FoxPro database File.DBF completely cleared from the records. left only structure. n the database were several MEMO fields. File.BAK remained. How to restore? Thanks.
Completely - in any way. If you find also tbk the file - then is possible. bak is
backup copy of the dbf file, tbk - a backup copy of fpt (there a memo of a field are).
However you were perhaps lucky, and actually fpt the file wasn't cleared.
And it is possible "to restore" of course simple renaming of bak file into dbf file. Of course then have to be reindexed the table, and if the structure changed, in general, to recreate the indexes from scratch. and perhaps "to treat"
the container Database dbc/dct (if you use it of course).
If so it doesn't turn out, then try to restore through DBF Viewer Tool. It well restores.
http://www.dbf.viewertool.com/
Come here on a forum and look at councils for this subject is there.
http://www.filerepairforum.com/forum/databases/databases-aa/dbase-iv-clipper-foxpro/1355-help-to-repair-dbf-file
If the file needs to be repaired, it is already damaged. To make things worse not only keeps a spare copy. And so - foxfix very powerful tool for recovery. Or a hex editor to see what is written in the tail of the file if the garbage - it cut before the "normal" data (aligned along the border post), to calculate the size and the size of the .dbf header records how many there really are, and to correct the record count in the header. Also there is a file header, which is similar to can (and should) rule in heh mode.
here you can see this topic. Here is the link to the forum
and even try to program DBF Recovery Kit
