I spent hours looking for a solution. I get this Error: 2091 message when try to open DBF file with the help of Clipper. I was able to open the file with no trouble before. Does anyone know what this message is or why it is occurring?
Hello.
DBF Repair Toolbox restores corrupted DBF database files, used in FoxPro, Clipper, dBase and other programs. Software reads a corrupted database and saves a recovered data into new one.
https://www.repairtoolbox.com/dbfrepair.html
FOXPRO DBF repair tool
File apparently is corrupted, and you may try to repair it with the tool at the link above.
SOURCE: Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
SOURCE: A Communication Problem Occurred. Open log file
Have seen following solution:
Copy wnaspi32.dll (from nero) in %windir%\system32.
Open cnfgvars.txt (from Scanwise folder)
Change /USE_ASPI from "0" to "1"
... Good Luck
By the way : Problem is comnig from usb 2.0 port
Try following :
Install Scanwiise (Scanner has to be unplugged)
Reboot
Plug in the scanner
Install the driver
SOURCE: Sanyo ADPCM 125 codec
I googled on your need and could find the following codec installer. I hope, this solves your problem. :)
http://www.sanyo-audio.com/download/software/download/icr/s_ldadpcm.exe
I am sorry, but the installer is a compressed executable. Extract with some extractor like winrar / 7-zip and then run the setup.exe. (It installs a device driver for windows - You have to accept it in windows XP)
If you are not able to extract/ proceed with installation, please comment here again and I will upload it somewhere as zip/rar.
Hope your problem is solved.
Bye. Have a nice day.
SOURCE: I have spent MANY hours
Here You can find a free mpeg converter for any type of files. What kind of file do You have? If it's .avi, probably Roxio creator cannot burn it because it is too big, and if You nave the menus on Your future DVD, I'm sure the reason is the size. On Mac it's easy. With toast titanium, You can select an option fit-to-DVD, and the video fits on standard DVD. Probably, the default compression options in Roxio aren´t sufficient. Try to search in advanced options compression level, or, You can convert with the MPEG Streamclip the video to mpeg video, by selecting a different level of compression, and then You can offer this file to Roxio. Try this. If it not helps, drop me a message.
SOURCE: HP Solution Center
When you click on the icon it is trying to open an xml file which is like a web page. The parsing error means there is an error in the page. I think the best way to cure this problem is to go to http://www.hp.com/#Support and put in the model number of your computer and download new drivers for your printer. You should also uninstall any current drivers you have from control panel's add and remove programs.
Hi, Fionn Morgan
I think you should first know the causes of such issues in detail. So, that it can be avoided in future.
Knowhttp://www.databasefilerecovery.com/blog...
