Apple iPhone 5 Logo
Marie Foster Posted on Jan 30, 2015
How come the ding goes away on messenger. This is on a I phone 5
Gilberto Beltrao
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 30, 2015
Gilberto Beltrao
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2705
Points
11
Marie, are you talking about the Text Messenger or Facebook Messenger? If it is the Text Messenger, try going to Settings -> Notifications -> Message. Once there, check if the "Notification Sound" is shown as set to "None". If so, click there and chose the ding you want. If you're looking for a solution to the Facebook Messenger, go to Settings -> Notifications -> and scroll down until you find the Facebook Messenger icon. Click on it and check if your notification is setup correctly as: Notification: On; Sounds: On. You can also check if the "Do Not Disturb" feature is disabled - this will put your phone to just ignore any income call, text, or notifications in general. Please follow the following link for more details about this feature. http://www.imore.com/how-to-setup-use-do-not-disturb-iphone-ipad
1 Related Answer
Anonymous
  • 4793 Answers
  • Posted on Sep 01, 2010
SOURCE: when i open drivers door
if the key is in the ignition, then that is the warning to remove same.if the key is not, then either you have left the indicators (for one side parking lights)or the lights are still on.
Testimonial: "answer was spot on..rear fog light was on..never heard tjat noise before..thank you"
1helpful
I put key in and right away a warning starts dinging. Checked all doors, no light on dash. It has been doing this two days now. Take key out it quits.
ALL CARS DO THIS, BROKEN DOOR AJAR SWITHES
IS THERE SEAT BELTS JAMMING A DOOR JAMB
NO CAR TOLD
MAKER
MODEL
YEAR,
NOT ONE CLUE WHAT CAR YOU DRIVE.
THE NEWER THE CAR THE MORE DINGS.(CHIMES)
FOR VAST THINGS.
KEYOFF THE CLUSTER GOES OFF LINE, AND CAN NOT DING EVER OFFLINE.
100% NORMAL THAT KEY THING
CHIMES,
SEATBELT SWITCHES FAIL
DOOR AJAR FAIL
TPMS TIRE PRESSURES WRONG
GAS GAUGE LOW.
HEAD LAMPS LEFT ON ,KEY OFF.
THE USERS GUIDE ON THIS SECRET CAR COVERS ALL THIS.
Turn off the ding ding noise on a 2003 bonneville SSEI? The emergency brake has been disabled but the ding noise will not go away
Wait, you are driving a car with the E brake disabled? Perhaps you should remedy this very dangerous act and fix the ding at the same time.
05 CHEVY venture ding ding sound when opening drivers door no key in ingnition sound goes away when start and close door
There is one solution your ignition switch is worn down i guess you cold start your engine whit a screwdriver.
Security bell keeps dinging even with seat belts on. 99 lincoln towncar
check the electrical connection under seat at seatbelt latch
1helpful
When i open drivers door only,there is a ding ding ding noise.goes away when door is shut..2001 elantra gls
High dinging or ringing noise Under hood
if it goes away when you turn the a/c on its the a/c clutch plate that is dragging and when you turn it on its pulled into the the a/c compressor and is turning all the time that's why noise goes away,you have to replace the a/c clutch.sometimes you can try prying with a screwdriver the edge that is dragging and noise will go away.
4helpful
Oil light flashing and dinging at a stand still even though oil is topped off. When we accellerate it stops dinging and the warning light goes away.
May be the oil pressure sensor is bad, but i think it is worn or damaged oil pump.. Try to replace the sensor, if no change, then the pump or all the engine is bad - so replace or rebuild it..
Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
