20 Most Recent Apple iPhone 5 Questions & Answers
Generally speaking, you need the Apple ID to reset your iPhone. iPhone needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPhone, you need to enter the Apple ID when your iPhone reboots.
reset-iphone-oxaxc0rwhkhzilrwacqreyis-5-0.jpg But if you have no Apple ID or passcode, you will have to reset your iPhone without Apple ID. To reset iPhone without Apple ID, you need first put iPhone into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Resetting your iPhone with this method will result in wiping all the data in your iPhone. The following steps will show you how to do that.
  1. Open iTunes on your computer and connect your iPhone to the computer with a USB cable.
  2. After that, turn off you device. Press and hold the Home button for 3 seconds.
  3. Put your iPhone into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPhone into DFU mode.
  4. When iTunes detects that your iPhone is in recovery mode, you can restore it now.
  5. Click on Restore iPhone. Then you will be notified after the reset and your iPhone will take a restart.
After resetting your iPhone with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPhone, you will get all the data swept from iPhone, and you can restore the files from your iPhone, iTunes backup or iCloud backup. However, you can't backup iPhone to iTunes/iCloud without Apple ID before you reset your iPhone . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPhone after factory reset without Apple ID.
via How to Reset iPhone without Apple ID
Apple iPhone 5 | Answered on Jan 23, 2018
I do not think you can but the best thing is to call apple there help is great and free.
Apple iPhone 5 | Answered on Jan 17, 2018
If you have an iCloud account you can backup your iPhone 4 by going to Settings, iCloud, Storage & Backup, Back Up Now.
Then when the new phone arrives and you get the option to restore from a backup choose Restore from iCloud Backup, choose your backup and wait. You new phone will be just like the old one was. Same apps, wallpaper, photos .etc
Apple iPhone 5 | Answered on Dec 25, 2017
Slim chance, but if they were important to you, you could try this.
It won't try to recover photos from your phone because iPhone 5 is not supported yet, but you can try letting it recover them from the iTunes backup file even though they were not successfully backed up.
I don't think there are many or any other options, so depending on how important they are to you, you can try it.
Apple iPhone 5 | Answered on Dec 05, 2017
The answer was already here:
Unlock iCloud iPhone 6S, iPhone 5S, iPhone 7, iPhone 6S+, iPhone plus
Download from:
http://unlock-icloud.com
Unlock and remove iCloud for:
All iOS
iPhone 7
iPhone 5S
iPhone 6
iPhone 6 plus
iPhone 6S
iPhone 6S plus
All iPad's
Remove iCloud activation lock, bypass iCloud lock
Real and working by software, work on all Apple iPhones
Trusted solution work 100% i recommand it's verified!
The software is easy to use and the support team from unlock-icloud.com offer good technical support with team viewer and video for unlock icloud and iphone repair solutions. The signal work excelent after i have used this software. The software is clean no viruses or other bad things like other software from internet.
With this software i managed to repair my iPhone 6 iCloud errors and bypass activation lock. It's a realy gsm repair tool.
Apple iPhone 5 | Answered on Nov 11, 2017
There is no way to delete icloud without knowing the password due to security reasons.
Reset icloud password:
iCloud Change your iCloud password select forgot password option.
Apple iPhone 5 | Answered on Nov 08, 2017
Open the settings app, scroll down to iCloud, scroll down to the bottom and delete account
hello, I also meet this error about my iphone, I get many help from this forum, and also bought many DIY repair tools from china supplier, and vipprogrammer help me fix this error. maybe you can try it. or contact they WhatsApp:+ 8615986801289
Link: http://www.vipprogrammer.com.
hope can help you!
Apple iPhone 5 | Answered on Aug 30, 2017
Acctually you don't need any specific software to install vpn on your iphone. You can do this using standard iPhone settings.
To make a new vpn connection in your iOS device you need to do the next:
  1. 1. Go to Settings > General > VPN
  2. 2. Click Add VPN Configuration
  3. 3. Choose PPTP VPN and enter you VPN account data. You will receive your VPN server, username and password in the e-mail
    Server address must be exactly as in your account data (without http://, www or any other symbols)
  4. 4. Save your VPN configuration. Once you have created VPN connection you can switch it ON and OFF on the main settings screen
Once you have created vpn connection you can switch it on and off on the main settings screen.
Sahrzad VPN How to Setup Guides
Apple iPhone 5 | Answered on Aug 29, 2017
This is probably too late but I really hope this can help you or others.
You may have encountered different errors during restoring and updating your device. You may have seen "This device cannot be restored Error " message from iTunes before and wondering what just happened. A common error usually exists because of just simple things. And so there are things you need to consider first when you're updating or restoring your iDevice. Here are some of those:
1, Stable Internet Connection.
2, Firmware Issue.
3, Security software.
4, USB cable and port issue.
Part 2: Common Solutions to Fix iTunes Error
Solution 1: Reboot your phone.
Solution 2: Replace the USB cable.
Solution 3: Checking your phone storage.
Solution 4: Restarting your computer and resetting your phone.
Solution 5: Look for more stable internet connection.
Solution 6: Update your iTunes.
Solution 8: Deactivating your antivirus.
Part 3. Fix iTunes Error by Setting Your Phone in DFU Mode
Part 4: Use FoneDog Toolkit to Fix the iTunes Error
Step 1: Choose "iOS System Recovery" Option.
Step 2: Connect Your iDevice to Your Computer.
Step3: Download Firmware.
Step 4: Start Repairing Your iOS.
Step 5: Repair Complete!
More information you can see the Guide: How to Fix iTunes Error Occurred While Restoring or Updating iPhone, iPad
Hope it can help you!
iOS System Recovery Guide How to Fix with Various iOS System Issues
Apple iPhone 5 | Answered on Aug 22, 2017
Try connecting it to iTunes and do a restore! if this doesn't work, contact Apple costumer service support!
Apple iPhone 5 | Answered on Jul 13, 2017
Probably.
Straight Talk has a web page to check your phone...
http://www.straighttalkbyop.com/?utm_source=IMM&utm_medium=cpc&utm_campaign=DR&utm_content=sitelink&utm_keyword={keyword}
Hai, What's your current locked carrier? You can unlock your iPhone 5 by using Remote unlocking method. It's one of the best and safe way to unlock your iPhone 5 .If you are interested in this method visit Theunlockarena.com . Here you can unlock your phone at low cost.
Apple iPhone 5 | Answered on Jun 06, 2017
You have to go to the new provider with the chip you want to run and get the phone reprogrammed to accept the new provider
Apple iPhone 5 | Answered on May 04, 2017
Try DFU mode first. If that doesn't kick iPhone out of recovery mode, turn to some data recovery program from Google. Or simply refer to this tutorial here: [Solved] iPhone stuck in recovery mode
Solved iPhone Stuck in Recovery Mode How to Fix
Apple iPhone 5 | Answered on May 03, 2017
1,Possible Reasons for your iPhone's Black Screen of *****
A. Hardware Damage
B. Failed Software Update
2,Common Ways to Fix the Black Screen issue in your iPhone.
A. Perform a Hard Reset on your iPhone.
B. Restore Factory Settings using iTunes
3,Best Solution: Fixing your iPhone's Black Screen issue with FoneDog
Step 1: Launch and connect.
Step 2: Detect the Affected iPhone Device.
Step 3: Proceed to the System Recovery Process.
Step 4: Download the Firmware.
Step 5: Perform Another Option for Firmware Download.
Step 6: Repair in Progress.
Step 7: Turn on the Device after Repair.
If you need to take it off you will need to restore the device in iTunes and set up as new. Restriction passcode are saved in backs ups and will come back if you restore your information.
If the restriction lock is not preventing you from fully using the device then you may just leave it.
Apple iPhone 5 | Answered on May 02, 2017
Hi, This is probably too late but I really hope this can help you or others.
Here is an article about it:
Reasons for Black Screen of ***** and How to Fix it
Hope it can help you !
Apple iPhone 5 | Answered on Apr 14, 2017
908 questions posted
Popular Products
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
iPhone Apple
  • iPhone Apple
Most Popular Question
given used phone 5 problem will not
  • Cell Phones
