This is a common problem, it has to do with the keypad flex. either the connector on the top part of your phone is unpluged or your flex is damaged. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to help
I had the same problem as everyone else here, however, I didnt believe it was a hardware problem
because the initial,"Hello Moto" screen was full screen, leading me to
believe problem was software... After a couple weeks of checking out
the forums this seemed to confirm my suspicions... I needed to flash
the phone to get it back, however, I am still a noob to phone software and every path I followed took me to the same place, nowhere...
Oddly enough, I used a tool provided free of charge from motorola at this address, http://direct.motorola.com/hellomot...my_software.asp
This is the free software updater for the V3 Razr, it will ask you to
input the date you purchased the phone, choose a date from last month
and it will allow you to download it free of charge. Once you install
the software it may tell you, as it did me, there are no new updates
available, it gives you the option to reinstall the current updates,
which I did and 30 minutes later, I have my phone back. This is the
slickest utility I have found to flash the phone and it got my
"bricked" phone back up and running just great, as well as saving my phone book and other settings... HIGHLY RECOMMENDED!!!
I hope this will help those of you, who, like myself, never have gotten
their phone wet. It may be that your bootloader is corrupted.
Just Click On The Problem or
Phone Model For Solution,
Motorola RAZR V3
Unlock Software Hardware
Motorola SLVR L7
Motorola RAZR V3i
Sony Ericsson K800i
Sony Ericsson W200i
I have fixedthe proble mt to my phone..it has to do with the tp part of your phone being loose from the bottom part..the flex connector is coming loose..so i would suggest that you take it to either repair store and have it fixed.it should cost about $30..and then your phone should work perfectly..but if u want a temporary fix just take out hte battery sweeze it a couple times and put the battery back and turn it on..if it doesnt work then you definitely need to get it repaired...
hope this helps you all
This just happened to me and I tried to take out the battery and nothing happened. NO suggestions.
Buy a new phone?
My Razar has no display only a black screen, everything else works I can dial and receive calls but cannot see what I am doing. I have tried taking the battery out, turning it on and off and nothing useful. Please help me
Thanks.
Also have a razr that will send and receive calls, but screen is black, as if it's off. No known trauma (dropping, water, etc.)
I followed your instructions and still not working. Where would I be able to buy a keypad flex for my Razr? Is it easy to replace myself? Thank you very much for your advice.
i have the same problem i've tried the same things to solve. nothing works
completly black screen everything else works. have tried everything else screen still will not come on.
I have recently experienced the same problem. My screen is black, and the keypad still lights up, but I can't see anything at all.
woww amazing i have the same problem, my cell works perfect, but my small screen is completely black n i cant see whos calling me, i did everything but nothing works, is there a solution for that??? i dont really want to exchange or anything!!!! i dont know if thats a problem with all motorola's cell phones cus i had one before n it did the same thing!!! hughhh it sux =(
evertime i turn my phone on the screen is blank but everything else. i can pus the buttons and recieve calls, etc. but i cant see what im doing. ive tried talikng the battery out ,i dropped, and i turned it on and off 4 times and still nothing
