Microsoft Windows 8.1 64-Bit - System Builder OEM - Windows Logo
Gunnar Saxhaug Posted on Jan 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I run a 32Bit application on a 64Bit Windows 8,1, if possible.
Tried to run it in earlier Windows modus.
Stuart Bassett
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 109 Answers
  • Posted on Jan 04, 2015
Stuart Bassett
Expert
Level 2:
New Friend:
Night Owl:
Answers
109
Questions
0
Helped
17095
Points
349
It depends what the application is. Some 32 bit apps wont run on 64bit windows. Others need additional files installing first like Microsoft's Visual C++ x86 redistributable. Have a look on Microsoft's website for help with installing 32bit apps on a 64bit Windows system.
4 Related Answers
Anonymous
  • 202 Answers
  • Posted on Jun 05, 2009
SOURCE: installation
well it can be done if:
your RAm size is up to 1Gb
processing speed is a minimum of 1.68 centrino or pentium 4
ultimitloozr
  • 489 Answers
  • Posted on Jul 07, 2009
SOURCE: 32 Bit or 64 Bit Windows Vista ( 3 Questions)?
Answer 1: The 64-bit version of Vista includes a 32-bit bubsystem to run 32-bit apps. I have not encountered a problem with it yet.
Answer 2: The power is consumed by hardware, not software, so with the same power settings you will see no difference in battery life.
Answer 3: Sorry, I couldn't locate any information about that model. You may be able to find appropriate drivers from other sources by pulling all available details from your existing drivers and searching the mfr website for them.
Anonymous
  • Posted on Nov 13, 2011
SOURCE: how can i find out whether im using windows xp 32bit or windows xp 64bit?
Go to My Computer, use the right button to click on it and go to properties. You will have all the info in there.
magnet0
Chuck Ricks
  • 242 Answers
  • Posted on Jul 13, 2012
SOURCE: LocationFree is not supported on Windows XP 64bit yet is supported on 32bit
The problem with the software (and dead product) is that is was created with the expectation that there would only ever be 32-bit processors. See if you can use or modify the instructions here:
http://flinchbot.wordpress.com/2011/08/23/installing-sony-locationfree-player-on-windows-x64/
  1. You should have a C:\Program Files (x86)\Sony\LocationFreePlayer directory.
  2. Manually create this directory: C:\Program Files\Sony\LocationFreePlayer\LFPC3\US.
  3. Go back to the (x86) directory and navigate to C:\Program Files (x86)\Sony\LocationFreePlayer\LFPC3\US.
  4. Copy these three files from the (x86) directory to the directory you created in step 3:
    1. LFPC3Help.chm
    2. License.txt
    3. OperatingInstructions.pdf
2answers
Is a canon MG3029 compatible with an ACER that has windows
Yes. But your version of Windows could be a problem.. lemme see.. Nope, no problems:
Operating Systems:
  • Windows 10 (32bit)
  • Windows 10 (64bit)
  • Windows 8.1 (32bit)
  • Windows 8.1 (64bit)
  • Windows 8 (32bit)
  • Windows 8 (64bit)
  • Windows 7 (32bit)
  • Windows 7 (64bit)
  • Windows Vista (32bit)
  • Windows Vista (64bit)
  • Windows XP
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
I got a NexxTech force feedback sterring wheel, the model is 261-8107, is there a driver compatible for windows 8
Have you tried the 32 bit driver? Many things will not have a specific 64 bit driver. You may need to install in compatability mode.
2answers
Have HP Pavilion N5435 with 930MHz freq and ~500MB RAM (can increase to 1GB) Can it support Windows 8 OS?
Does you system meet this criteria: Windows 8: system requirements
  • Processor 1GHz or faster
  • RAM 1GB (32bit) or 2GB (64bit)
  • Hard disk space 16GB (32bit) or 20GB (64bit)
  • Graphics card Microsoft DirectX 9 graphics device or higher
Windows 8: additional requirements
  • To use touch A tablet or a monitor that supports multi-touch
  • To access the Windows Store and to download and run apps An active internet connection and a screen resolution of at least 1024 x 768 pixels
  • To snap apps A display with a resolution of at least 1366 x 768 pixels
Read more: http://www.pcadvisor.co.uk/features/windows/3358892/windows-8-system-requirements/#ixzz2z83szG8E
I have windows 8 and my mitsubishi cp-D70Dw won't install on my PC... I've downloaded a new driver? Help!!
dude check first your windows 8 OS is 32bit/64bit Operating System.
and den check is the drivers downloaded is whether 32bit/64bit,
If your windows 8 is 64bit den download 64bit driver for your mitsubishing and install.
How do I fix this? Unsupported 16-Bit Application
You are trying to run a 32bit version program on a 64bit system, this is not allowed. Try obtaining the 64bit version of the program and load that or alternatively try CutePDF, it works well on any system.
1helpful
2answers
My computer is telling me I can not run an x86 build of this utility on a x64 platform. I am running windows 7. What do I have to do to be able to run this program for the new Futura CE-150
x86 means 32bit operating system , x64 means 64bit operating system.Windows is divided into to categories 32 and 64 bit. In your case you might be trying to install 32bit operating system's software or a application in an 64bit operating system running machine. If you are getting the above mention error message than it is clear that your window 7 is 64bit operating system and a 64bit operating system doesn't support 32 bit's software. You only can install software or application you are meant for 64bit supporting.
If you want to know more about 64 and 32 bit CLICK HERE
GOOD LUCK.
2answers
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
Helo any1 there...i hv a compaq pressario cq40 144tu laptop with 2gb ram installed with windows 7 home basic 64 bit..it is recently crashed now i want to install 32 bit windows 7 on it.but the installation...
Downgrading from 64bit to 32 bit is not possible
the drivers that work in 64bit don't work in 32bit
64bit windows on a 64bit processor would work faster and more efficiently than a 32bit version of windows, i'd recommend against installing 32bit Win7 when you already have 64bit
if you do end up downgrading visiting the Compaq site and looking in their downloads section should lead you to some drivers for your laptop
however, if you got Win7 64bit as stock with your laptop 32bit windows might not be supported by the manufacturer
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
