Water flow but not pilot light ignition. is hydro generator the problem?
SOURCE: Bosch tankless GWH 1600 H NG won't always ignite
The manual says to hold a match near the pilot while the ignitor is
trying. It says that if the unit lights the pilot orifice may be dirty
or clogged. Then the manual says to check
the voltage on the igniter. It should be 1.3 volts DC minimum if it is not means the electronic control box is defective.
Let me know the status ...Kevin
SOURCE: no hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
SOURCE: Have a Bosch tanless water heater. Pilot won't
sounds like blockage pilot jet nipple needs cleaned best of luck
SOURCE: we have a 3 year old Bosch GWH 425 HN tankless LP
suggest you complain to Borch sometimes lemons get through best of luck
