20 Most Recent Bosch & Tankless LP Hot Water Heater Questions & Answers
It sounds like a bad flo switch. If not, then the problem is more likely in the mother board. Call Bosch back and ask for a supervisor right away. The peons sometimes are given advancement according to how many calls they handle, so they have a time crunch. Go right to the supervisor. Good luck!
Bosch & Tankless... | Answered on Feb 05, 2018
or check pressure switch if voltage at outage also check gas pressure
Bosch & Tankless... | Answered on Jan 11, 2018
Try Googling (bosch)(FW11B)(manual) without parens.
Bosch & Tankless... | Answered on Nov 05, 2017
Look for a water temp control on unit. Otherwise a lower temp can be attained by having a higher water flow to minimize temperature buildup in heating coil.
Bosch & Tankless... | Answered on Sep 06, 2017
have a plumber check the installation as it appears that there is a temp control mixer in the kitchen line that should be in the bathroom line
Many states and countries now have made it mandatory the full uncontrolled hot water cannot be used in a bath, shower, wash basin but has to limited to a max temp of 70 C to prevent burns to the skin
Bosch & Tankless... | Answered on May 29, 2017
You either have a weak spark from your ignitor which needs replacing, a bad elec connection to the ignitor, or it needs to be repositioned nearer the burner. Check connections and try repositioning it before you install a new on.
Bosch & Tankless... | Answered on May 08, 2017
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Bosch & Tankless... | Answered on Nov 01, 2016
The S 13 BP is a simple unit that does not have a pilot light. It uses electronic ignition on demand, which is what you hear clicking. If there is no gas going through and you've verified there is gas to the inlet, then it has to be the gas control valve.
Bosch & Tankless... | Answered on Feb 11, 2016
call your plumber and have it serviced possibly just needs the thermocouple replaced .
Bosch & Tankless... | Answered on Jan 08, 2016
Solution for a code 10 or 99 (for my own reference as much as anything!)
Hit change and the down arrow on the controller for 3 seconds.
Wait for the controller to beep and display 00 before using the down key to display 93.
Hit the On/Off button until 000 is displayed on the screen.
Press change and down simultaneously and the controller should revert to the pre set temperature. Hey presto! Hot water!!!
Bosch & Tankless... | Answered on Oct 12, 2015
Make sure breaker is turned on. If that isn't it tell me model number and maybe I can help you more
Bosch & Tankless... | Answered on Apr 20, 2015
Check gas pressures first especially on low setting. Ensure gas burner is clean get unit serviced if over 2 years old. Check or replace water flow sensor & clean inlet filter.
Bosch & Tankless... | Answered on Feb 05, 2015
Before calling service technician, read manual for fault finding and possible solutions.
http://waterheatertimer.org/pdf/Bosch_water-wizard.pdf
http://waterheatertimer.org/pdf/Bosch_13P_16P_In.pdf
Following links talk about keeping pilot lit, and describe location somewhat. Bosch water wizard has standing pilot light.
http://www.fixya.com/support/t2961646-water_wizard_10p_pilot_light_keeps_going
http://www.fixya.com/support/t2960079-bosh_water_wizard_10p_pilot_light_keeps
http://www.fixya.com/support/t6182021-bosch_10p_tankless_hot_water
1) The manual does not show diagrams you asked for.
2) Website that sells Bosch parts does not show parts for water wizard, nor does Bosch site for parts: Instruction manual says: replace pilot injector
http://www.boschhotwater.com/HelpfulResources/PurchaseParts/tabid/837/Default.aspx
http://www.houseneeds.com/shop/heatingproducts/waterheating/parts/bosch2400espartsbuy.asp#
3) Searching "pilot injector for Bosch Water wizard" turns up fixya questions which is generally bad news for do-it-yourselfer because it means information sources are through service technician.
4) As a general rule, tankless are not do-it-yourself repairs or installation because they are affected by so many internal and external factors, including air quality, air flow, venting, other gas appliances, gas pressure, gas supply, water pressure, water flow, plumbing problems, water quality, plus internal parts and including any combination of things listed above..
Replacement parts each come will disclaimer.
Send some photos so the internet can see the problem.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Bosch & Tankless... | Answered on Nov 18, 2014
http://www.ps2netdrivers.net/parts/bosch.gwh.425.hn/
Bosch & Tankless... | Answered on Nov 11, 2014
Bosch & Tankless LP Hot Water Heater  Logo
295 questions posted
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Sheldon Dedek
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
View Most Popular
Bosch Water Heaters
  • Bosch Water Heaters
Most Popular Question
spark igniter keep sparking after burner
  • Water Heaters
