20 Most Recent Bosch Thd2021gb Filtrino Fast Cup Hot Filtered Water Dispenser Questions & Answers
It took me ages to get his to work - seems that on the THD2023GB (Black) Filtrino, you push and hold the temp. set button for 10 seconds to get he descale programme running.
Bosch Thd2021gb... | Answered on Feb 09, 2018
id say if the plumber charged you to call him back right away
Bosch Water... | Answered on May 06, 2019
ABSOLUTELY NOTHING YET AS IT HAS NOT FAILED . WHY MAKE A MONEY PIT OF IT BEFORE ANY THING GOES WRONG ?A GOOD PRE-FILTER MIGHT HELP AS MUCH AS ANY THING ELSE
Bosch Water... | Answered on Mar 26, 2019
It could be the thermostat sensor They usually have a carbon buildup. They are easy to install and not that expensive. Good luck
as with all water heaters they need flushed once in awhile to get rid of sediment in the bottom of the tank . knowing this from the get go most of us never seem to get around to doing it . even myself but I do have a unit that is supposed to prevent this by the dip tube that was built in has circular action in the bottom of the tank
Bosch Water... | Answered on Jan 20, 2019
iF YOU RAN OUT OF GAS, THE LINES MAY NEED TO BE PURGED OF AIR. dISCONNECT THE GAS FLEX AND TURN THE GAS ON TO PURGE THE AIR FROM THE LINE. dO THIS UNTIL YOU GET A STRONG SMELL OF GAS. aLSO, WHEN YOUR UNIT TRIES TO LIGHT, BUT THERE IS NO GAS, IT WILL TRY TO LIGHT THREE TIMES. aFTER THE THIRD ATTEMPT, THE UNIT LOCKS OUT. yOU MAY NEED TO RESET IT BY UNPLUGGING IT, OR IF IT IS HARD WIRED, JUST TURN THE BREAKER OFF FOR 10 SECOINDS AND THEN TURN BACK ON. tHIS WILL RESET THE GAS VALCE TO RELIGHT. gOOD LUCK!
Bosch Water... | Answered on Oct 03, 2018
Error code EA - No sparks for the electrodes
The ionization electrodes are not making sparks when water is flowing. There are many reasons for this problem and here are some; low gas pressure, fan speed is low, wire connections are loose, the air in the gas line, no gas.
Bosch Water... | Answered on Sep 08, 2018
Bosch Thd2021gb Filtrino Fast Cup Hot Filtered Water Dispenser Logo
6 questions posted
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Sheldon Dedek
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
View Most Popular
Bosch Water Heaters
  • Bosch Water Heaters
Most Popular Question
descaling instructions bosh filtrino
  • Water Heaters
