Toshiba 32L4200U - 32in Class  31.5in viewable  LED-backlit LCD TV Logo
R
Robert D Hirsch Posted on Oct 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I turn on a Toshiba 32L4200U without the remote?
How to turn on without remote
Mikey
Level 3:
Top Expert:
  • Toshiba Master 6,904 Answers
  • Posted on Oct 24, 2014
 Mikey
Toshiba Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1623607
Points
26106
Yes! As you face the TV screen on the left hand side panel, the top button is the power button.......it will either turn on or to standby......if it goes to standby press one of the next 2 buttons which are the channel up and down buttons!
I have a toshiba tv without a remote and I'm trying to set up my magnavox to the tv without a remote and can't figure it out.
Buy a universal remote control and program it to work with the television and DVD player you have.
How do i change the the antenna from cable to antenna
which of these TVs is yours?
Originally supplied with models: 19AV600U, 19C100U, 19SL400U, 22AV500U, 22AV600U, 22C100U, 22SL400U, 26AV500U, 26AV502R, 26AV502R/U, 26AV502RZ, 26AV502U, 26AV52R, 26AV52U, 26C100U, 26C100U1, 26c1100u, 26SL400U, 32AV500U, 32AV502R, 32AV502RZ, 32AV502U, 32AV50SU, 32AV52R, 32C100U, 32C100U1, 32C100U2, 32CV510, 32CV510U, 32DT1U, 32E200U, 32RV530U, 32SL400U, 37AV500E, 37av500u, 37AV502R, 37AV502U, 37AV52R, 37AV52U, 37CV510, 37CV510U, 37E200U, 37RV525R, 37RV525RZ, 37RV52R, 37RV530U, 40E200U, 40E200U1, 40E200U2, 40FT1U, 40G300U, 40G30U, 40RV525R, 40RV525U, 40RV52R, 40RV52U, 40XF550U, 40XV640U, 40XV645U, 40XV648U, 42AV500U, 42RV530, 42RV530U, 42RV535U, 46/40/55S41U, 46G300U, 46G30U, 46RV525R, 46RV525U, 46RV530U, 46RV535U, 46RV53CU, 46SL412U, 46XF550U, 46XV640U, 46XV645U, 46XV648U, 52RV, 52RV530U, 52RV535U, 52RV53U, 52XF550U, 52XV645U, 52XV648U, 55G300U, 55HT1U, 55S41U, 55SL412U, 19AV600UZ, 19SL410U, 24SL410U, 32C110UM, 32FT2U, 32SL415UM, 40E210U, 40SL412U, 55G310U, 42RV525R, 32C100UM, 32DT2U, 40E210U1, 65HT2U, 32RV525RZ, 46RV525RM, 40G300U3, 46G300U1, 32C120U, CT90302 Programming Instructions and Codes, CT90302, 75022871, 75017678, 32E20U, 37E20U, 40E20U, CT90325, 75028874, 24SL410UM, 32C110U, 32SL410U, 32SL410UM, 40E210UM, 46G310U, 32C110U1, 32DT2U1, 40FT2U, 32C10U, 19L4200U, 24L4200U, 32L4200U, 40L5200U, 46L5200U, 50L5200U, 26C100UM, 40E200UM, 55HT1, 50L2200U, 39L1350UC
1helpful
Can I reset my Toshiba 30HF84 without a remote
Since most passwords require a number sequence to be entered I doubt it can be done without the original remote and the correct code numbers.
How do i turn the Panel lock function off on my Regza 42xv600a without the remote?
This may not be possible; it may be designed to prevent children from operating the set without an adult with the remote present.
You can probably buy an original remote or a known substitute from:
Remotes.com
1helpful
No remote - toshiba vhs w522
Unfortunately, many models are now without menu buttons. You will probably want to go to the Toshiba website and request a replacement remote, or try to find a remote that will work with all toshiba models.I don't recommend a universal one, only because they can sometimes be junk, if they are intended to control many different kinds of devices. You may want to try a single-device universal remote instead.
2helpful
2answers
Programming remote to toshiba Tv
Depending on the universal remote you can usually program the remote without knowing the codes. One way is to turn on the television, then follow the basic programming instructions for the remote, but instead of entering a code, hit the power button over and over again until the television turns off.
I hope this helps.
Ken
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
