Usb2 enhanced host controller not on device list
SOURCE: I NEED A DRIVER PCI
Try below site:
http://www.usbman.com/WebDrivers/Ali%20USB%202.0/aliehci_152.zip
SOURCE: SCSI/RAID Host Controller/Driver cannot be found
Please try the following methods:
1. UNINSTALL the DRIVER
-Open the Driver tab on the Device Properties box
-click Uninstall button to remove the current driver
-after the uninstall process is complete. Restart your computer.
Note: It is recommended that you use s Registry Cleaner tool (ex. CCleaner.com) to scan & remove any left behind information of the uninstalled driver to ensure complete removal.
-next, reinstall the Device Driver, to do this, in Device Manager window, right click on the Device Type of the Device you uninstalled & then select the 'Scan for Hardware Changes' command to launch the Add Hardware wizard & reinstall the Driver.
2. Run the Troubleshooting Wizard
-open the faulty's Device Properties box in Device Manager
-on the General tab, click the Troubleshoot button, this will launch the wizard that will enable you to troubleshoot your device
-follow the instructions in this wizard to diagnose the problem with your device & resolve it.
Best regards
SOURCE: what graphic card do i need to watch movies from pc to tv
U can install nvidia graphics card
if you are referring to usb drive or you could download them http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller http://majorgeeks.com/downloads35.html also this link will provide you with many freeware and share drivers hope this helps you
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question/exclamation mark ? ! or a red X you will need to update the driver
right click to reinstall drivers
if you can see your usb drive but its not working
if your computer came with a motherboard disk the drivers could be on it
ports(com&lpt)right click update driver
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don't use numbers and / - you might have to try a few times to get it right
also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
hope this helps you
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if you dont have a motherboard disk you will need to download the drivers http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
hope this helps you
