Question about Fujitsu (MPG3307AH) 30.7 GB Hard Drive
I am using a fujitsu mpg3307ah in an external usb mode and need to install the correct driver in my vista laptop.
Posted by Bertie Brooke on
Brian Sullivan
  • Fujitsu Master
  • 27,725 Answers
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)don't use numbers and / - you might have to try a few times to get it right
also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Posted on Sep 26, 2011
Notebook Lifebook E8110 - some keys sometimes dont work. Backspace, and keys around "mushroom" pointer like r,f,g,h// I tried in Word and Notepad and nothing, in Internet Explorer they work. Now...
Fujitsu America - Support - LIFEBOOK T734 Notebook PC
support.fujitsupc.com/CS/.../supportsearch.do?...Notebook%20PC
USB 3.0 devices not working as Super Speed when resuming from Standby ... Fujitsu LifeBook T734 Notebook PC; Softex OmniPass; Microsoft Windows 7; Microsoft ....When setting up external monitors on the VGA or DVI port do not change the .... Vista and XP Tablet PC act differently at this point; both need to make some ...
[PDF]E8110 spec - Fujitsu
Dec 26, 2015 | Fujitsu LifeBook E8110 Notebook
Fujitsu fi-5750c Flatbed Scanner need to
The back panel of the scanner should have a USB connection to the right of the SCSI ID selection switch (the farthest right on the back). Just get from any source a standard male/male A/B USB cable.
Then get the correct drivers here: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v921720c.html . Additional software may be found here: http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers-downloads_index.html
I hope this helps.
Apr 30, 2010 | Fujitsu fi-5750C Flatbed Scanner
Starts up runs then hangs up
What is your OS? If you are using Vista then there could be an incompatible piece of hardware which will cause it to hang up. Try installing a different OS. If this is not the problem, it could be the incorrect drivers have been installed. Go to the manufacturers website to make sure you have the correct ones for your computer.
http://www.notebook-driver.com/fujitsu/fujitsu-lifebook-t4020-tabletpc-windows-xp-tablet-drivers/
Nov 08, 2009 | Fujitsu LifeBook T4020 Notebook
How to connect usb conection from my data one "UT-300R2U" modem to compaq laptop.we have usb cable and driver cd but drivers are not installed in my laptop.plz give me the complete solution for this...
If you are using Windows Xp, just connect the modem using USB/LAN it will be automatically detected & software for it will be installed. Then you can just set up a connection, put in your username & password, done.
If you are using Windows Vista / Windows 7, modem in LAN mode will be installed automatically like XP, but not in USB mode. Because there's no USB driver for UT300R2U (BSNL modem) in Vista. You need to find a ZTE Remote NDIS device driver, install it & then you can connect. Hope this will fix your problem.
May 12, 2009 | Computers & Internet
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
I need audio driver for lifebook c series 2210
Go to the Fujitsu WEB site, to the support/download page and search for the Vista drivers for your model laptop.
Jan 10, 2009 | Fujitsu LifeBook C2340 Notebook
Drivers for windows vista 64 bit
i want wireless senao engenius driver vista to HP laptop
Dec 10, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Vista driver for Intel camers
You need a USB video class driver to use in vista. this link says it's for a genius webcam but the driver is a generic one for vista-supported usb cameras(amongst others devices), so it should work for you.
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/GENIUS/Genius-Eye-320-webcam-Vista-driver-10.shtml
happy snapping and filming,
chris
[email protected]
Sep 13, 2008 | Intel Create And Share Camera Pack Webcam
Trouble with sound /amilo d8830
Try:
Uninstall driver and restart the computer
GO with safe mode and install just from device menager
Oct 27, 2007 | Fujitsu AMILO D-8830 Notebook
Fujitsu (MPG3307AH) 30.7 GB Hard Drive Logo
225 people viewed this question
Top Fujitsu Computers & Internet Experts
Ekse
Erni Mallari
Erni Mallari
Lee Hodgson
Lee Hodgson
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
